Hi I just wanted to share my experience with this wonderful program. I have been a dvd decryptor/instant copy and dvdcopyxpress user for several months ,now I was shown by a friend clone dvd and I was impressed big time the transcoding and burning process took 1 hour and it just made instant copy look lousy when compared to time and burning quality. I am totally convinced that clone dvd is fast becoming a heavyweight contender in the back up world and im leaving ic behind for dvd decryptor/clone dvd because when I used dvd 9 discs for backup with ic I would always run into problems but when it came to clone it handeled everything I threw at it with no bugs whatsoever so my vote is for clone dvd..![]()
Results 1 to 30 of 41
I too like CloneDVD a great deal.
I use it paired with AnyDVD, so it's even FASTER if you can believe it.
However, there are times when I want more control than CloneDVD gives me, and then I use DVD Shrink.
But yes, I think that IC is going the way of the dodo, unless they release an update that makes it like 500% faster.
- Gurm -
it's a great software, mainly becose you can select the extra you want to keep or not.. only down side is the quality. a bit less than dvdshrink 2.3
I find the quality to be better when doing a low-compression transcode. And I expect it will improve overall as Olli updates it. Problem is he spent a LONG time getting AnyDVD going, and troubleshooting it. But now that AnyDVD is pretty stable I expect CloneDVD updates quickly.
- Gurm -
I like Clone DVD. I had one DVD bachelor party that with ANYDVD would not even start up but I had problem with ANYDVD with DVD2ONE also but over all I like CLONE DVD
Spiderman, have you updated to the latest AnyDVD?
I too had trouble with DVD2One + AnyDVD in earlier versions.
- Gurm -
I too had ANYDVD problems until I updated to the latest version. Now it works great with all the software I use it with, e.g. InstantCopy, CloneDVD, DVDShrink, etc.
I too like Clone DVD. It's nice to be able to just rip the movie but still keep the full menu structure and extra soundtracks. I just wish it would allow you to put a simple picture slide of, say "Not Available On This Disc" instead of a low bitrate grey screen that lasts for the running time of the removed file. However the "dummy" files it creates are still much smaller than DVD Shrink with it's "Still Pictures" mode, so it allows for the most bitrate to be used for the actual movie.
you can replace the gray file with anything you want as long as you use ifoupdate and ifoedit to get vts sectors.
from the authors site FAQ
Does CloneDVD support DVD-5, DVD-10, DVD-9 and DVD-18 DVD movie?
CloneDVD support DVD-5(SS-SL or Single Side Single Layer, 4.7 G) and DVD-10(DS-SL or Double Side Single Layer, 9.7G). Currently version does not support DVD-9(SS-DL or Single Side Double Layer, 8.5G) and DVD-18(DS-DL or Double Side Double Layer, 17G) but will be available soon anyway. -
CLONEDVD is a great programme and with the plugin (anydvd) now no need for decryptor do it all in one programme
K2,
It READS DVD-9... it just doesn't support BUILDING 9GB images.
And there's really no point to THAT, is there? (Since there's no such thing as a dual-layer burner!)
- Gurm -
Originally Posted by energy80s
I downloaded the trial version and it tells me that it doesn't do layer 2 movies. If I purchase the key to unlock it will it do layer 2 movies?
Does anyone know?
Thanks in advance. -
I'm failing to understand. It DOES DO 2-layer movies... it rips them.
It will not CREATE a 2-layer movie at this time because that is STUPID for the target audience. JEEEEZUS people how hard is this to comprehend?
Y'know what? Lemme test it.
Ok, I'm putting in Lord of the Rings: Fellowship of the Ring, Extended. Total size is 6.89 GB. Hold on...
CloneDVD says...
"Creating DVD Files". No, I'm not gonna wait a half hour for this to finish. IT GODDAMNED WORKS.
Why do people keep insisting that it doesn't do dual-layer discs? WHY?
- Gurm -
Thanks for your help Gurm.
I have CloneDVD ver 1.25 Trial Version and Elby Clone DVD 1.1.7.1. Do you have to have the full version in order for it to do DVD-9 DVD's?
When using the 1.25 Trial Version it says in an error message that CloneDVD doesn't support DVD-9 at this time.
When using the Elby 1.1.7.1 version it is looking for video files on my hardrive (which there aren't any) Again, do you have to have the full version in order for it to work?
There is something I am doing wrong and would like it know if anyone can help me out.
Are there any guides that would help me out as well.
just a guess as i don't use this software
maybe it's saying that it won't burn a dvd 9 disc -
I don't think so, it says it supports DVD-10 which can't be burned to DVDR
CloneDVD support DVD-5(SS-SL or Single Side Single Layer, 4.7 G) and DVD-10(DS-SL or Double Side Single Layer, 9.7G) -
Originally Posted by thayne
is 2 dvd5
usually fullscreen and widesceen version
so it will support that as that is the same as a dvd 5 -
What is the point of the software if it can't convert a large dvd to fiit onto a DVDR???? I mean DVDDecryptor is free and it can rip and burn a DVD-5 so why would anyone pay $45 for something that basicly does the same thing as freeware apps?
LOOK! CLONE DVD CONVERTS ANY COMMERCIAL 9Gb DVD DISC DOWN TO 4.36Gb!
I DON'T KNOW WHY YOU SHOULD THINK OTHERWISE!
.... sometimes you just have to SHOUT .... -
People don't use clone from a bad taste from the old program..
It didn't work
and on at least one system of mine, crashed the OS permanently (98se)
GREAT TO SEE THE NEW one works
Don't you need to have a small microsoft component called .NET to let the new clone work?
I've heard some people won't reccomend that you install .NET tho' -
btw, there are 2 programs called CloneDVD.
the one from elby wich does of course dvd-9 to dvd-5 copy, and one from another company (the 1.25 version) wich does not !!
dont mix them.
look here for the "real" one: http://www.elby.ch/en/products/clone_dvd/index.html
Can't clone DVD with CloneDVD2
By Navop in forum DVD RippingReplies: 4Last Post: 6th Mar 2012, 11:36 -
Best & easiest way to clone a dvd?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 30th Jul 2010, 09:00 -
How tp properly clone a DVD using Toast 10
By Jabroni4872 in forum MacReplies: 2Last Post: 28th Apr 2009, 08:25 -
clone dvd 2
By fitos in forum DVD RippingReplies: 2Last Post: 8th Feb 2008, 17:16 -
Newbie that doesnt know much and doesnt know where to put her query.
By emilymeg in forum Newbie / General discussionsReplies: 22Last Post: 10th Jun 2007, 12:46
