I have almost the same computer specs as you. What kind of conversion are you doing? It looks really fast. Is it Divx to VCD or something else? Have you tried Divx/Xvid to DVD (How fast is it)?Originally Posted by subclubkid
Results 31 to 38 of 38
ok, here's my results for encoding an avi file (~6GB, ~30 minutes):
You can examine my system specs in the profile. EDIT: sorry, in Computer Details.
No filters selected.
2 pass vbr (4000 min, 8000 max)
every thing else standard DVD-NTSC template
On the CPU tab of Environmental Settings:
With hyper-threading disabled in the bios, multi-threading enabled in CPU environment tab, 256MB prefetch video and 4096MB cache
1:04:15
With hyper-threading enabled in the bios, hyper-threading enabled in CPU environment tab, 256MB prefetch video and 4096MB cache
0:55:56
Not much of a difference IMHO. Am I doing something wrong or are there other suggestions on the encoding specs. I can run some other configurations if someone is curious about other setttings. -
funkguy4 wrote:
Are you saying that hyper-threading and multi-threading are the same? In that case you're right I did not disable multi-threading in Options->Environmental Settings->CPU when I disabled hyper-threading in bios. That could explain why there is little difference. I didn't think they were the same beast but on second glance, the choice reads as follows:when u dont enable hyper-thread in bios, u probably shouldn't in software.
Use Hyper-Threading Technology (multi-threaded)
I'm going to take a small, about 1 minute clip, and run with different environmental settings and different encoder settings. It will take me a few days since I have to work this weekend but I'll post results when done. -
After much gnashing of teeth and what not, I've tallied some numbers using TMPGEnc on a 00:01:03 avi clip on my home computer and my work computer. The results can be found here:
http://webpages.charter.net/kylerh/Performance/perf.htm
If you would like to see some other set of numbers just say so. I can also produce numbers on a 700MHz P3 laptop if that's of any interest. -
obiron,
Thanks for the info, some very interesting results there.
SLICK RICK
Extra fan for Hyper 212 EVO
By Stealth3si in forum ComputerReplies: 13Last Post: 25th Mar 2012, 11:01 -
Xvid4psp and hyper threading.
By Raven2827 in forum Video ConversionReplies: 2Last Post: 23rd Jun 2010, 22:13 -
i7-920 Hyper-threading
By wulf109 in forum ComputerReplies: 14Last Post: 8th Apr 2009, 20:25 -
How to use Hyper Terminal in TCP/IP(winsock) mode to communicate ?
By SingSing in forum ComputerReplies: 14Last Post: 31st Aug 2008, 07:37 -
Hyper Media Centre Advice
By greer1988 in forum Media Center PC / MediaCentersReplies: 1Last Post: 8th May 2008, 06:14
