I just updated my system and now have HT, and was wondering how I go about making sure that its being used to its full capacity. I checked the guides, and their website, but not much info given.
I went to Enviroment setting-and there was a box I could check to use Multi CPU's and its set at 2, but then there are some other check boxes I dont understand. I'm at work so I cant list them off my head, but could someone give me some pointers.
Results 1 to 30 of 38
"Sleep-
Those little slices of Death;
How I loath them." -
click off "use hyperthreading"
close and re-open and it should show 4 cpu's
it should show 4 cpu 's also in task manager
you must use win XP ..
you must enable HT in your BIOS ..
some programs run much slower with HT , so be aware ... -
HT is already set in my BIOS, I will try that other thing when I get home
And for what you said about programs running slow, is that with it set in BIOS, or turning it on in TMPgenc? Sorry but I'm new to the HT world."Sleep-
oh and is MultiThreading the same thing as Hyperthreading? I'm looking at Tmpegnc right now and dont see Hyperthreading, but I do see Muti
"Sleep-
what version of tmpgenc are you using ---- it says 'hyperthreading' in my version , 4 cpu (under CPU tab)
then check off everything in "multithreading" , prefetch video (1/4 of your total memory)
cache (lots -- i set mine to 10 gig, 5 is prob.. enough though for most people) -
Plus 2.5, and under my CPU tab it just lists Multithread, and it says 2 CPU's. Any ideas?
"Sleep-
I have 2.53.35.130, which I just downloaded and updated mine, and I'm not seeing it. I do see the Multi Thread thing, and it says 2 procs.
And some of those options you listed arent on there either.
Did they take stuff out on a new release? Is it possible to get an old copy of the one you have?
man this sucks."Sleep-
latest version is TMPGEnc Plus (English), Ver. 2.520 (2.520.54.163)
http://www.pegasys-inc.com/e_download.html
non the less -- i stuck with this version i am using because of a few bugs in some newer versions --
maybe they took multithreading out now...
Version : 2.59. 2002/11/14
Corresponded to Hyper Threading Technology. -
Ok I found it, thanks for the help man.
"Sleep-
Well I got it working, and OMG I didnt know converting movies could be this fast
Looks like its time to update my software"Sleep-
Dare I ask?????
How fast?????? I have my eye on a 2.4GHz P4 800MHz fsb with HT..... -
about 40% + speed increase if you use HT and the settings i posted above , using 2 pass -- compared to non HT and default settings .
I have a 2.4 HT with 800 FSB with some PC3200 RAM and to convert a 9 minute clip it takes about 3 minutes, sometimes alittle less, sometimes alittle more. Coverting a 31 minute clip took 11 minutes and so on.
Quite a jump from what it used to take.
The best part is my motherboard supports up to like a 3ghz CPU so this fall when prices drop again I might pick up a new CPU.
Oh and thanks again BJ_M"Sleep-
i made a mistake though .. i have a dual xeon system and it shows 4 cpu .. your single in HT mode would show only two ..
i keep thinking of dual xeon systems ..
sorry about that .. -
When you say a clip, what kind?Originally Posted by subclubkid
2-pass VBR, CQ or CBR
What resolution? VCD, SVCD or DVD
What was the source? DVD, AVi, etc
I did a 1 hour and 20 min Divx to SVCD using QC, motion search set to high and fast resize last night and it took about 5 hours on my 2GHz P4
Thanks -
sorry I didnt post all the info
The source was wmv and I did CBR to VCD for the 9 minute clips.
I dont remember what the other ones source was, but the output was at the same settings listed above.
I'm sure the time would increase if I was converting to DVD or SVCD."Sleep-
My boss ia getting me a new PC with a 2.4GHz P4 with the 800MHz FSB and Hyperthreading, 1Gig DDR Ram, a Serial ATA drive, GeForce 5200 FX Ultra and a DVD+R/RW next week!
No for work... Right now I have a P3 600 with 384MB ram, uggg!
Damn my work PC will be faster than my home PC..... Can't have that! -
Ask you boss for a comp with dual-channel DDR. It's cheaper.........also, ask him to get a 533FSB comp. Also, it will give you an excuse to get a better comp for home!Originally Posted by thayne
No, Im getting the 800MHz FSB and yes DDR, I think it was PC 3200Ram
Well I could just do all my video stuff at work
And kick back at home LOL!
At home I have a P4 2.0GHz with 512 megs PC 2700 DDR ram. It's not bad, but I's like a faster one
What does the cache setting do? Does it always increase the conversion speed regardless of project coversion setting or do you have to turn on multi-pass VBR or something of that nature?
Extra fan for Hyper 212 EVO
By Stealth3si in forum ComputerReplies: 13Last Post: 25th Mar 2012, 11:01 -
Xvid4psp and hyper threading.
By Raven2827 in forum Video ConversionReplies: 2Last Post: 23rd Jun 2010, 22:13 -
i7-920 Hyper-threading
By wulf109 in forum ComputerReplies: 14Last Post: 8th Apr 2009, 20:25 -
How to use Hyper Terminal in TCP/IP(winsock) mode to communicate ?
By SingSing in forum ComputerReplies: 14Last Post: 31st Aug 2008, 07:37 -
Hyper Media Centre Advice
By greer1988 in forum Media Center PC / MediaCentersReplies: 1Last Post: 8th May 2008, 06:14
, I been buggin' you for goods these past few days.
