I'm having a problem when I insert scene selections for a movie file with Ulead DVD Movie Factory. I can insert them just fine, but after I finish and create the video_ts folder and then open PowerDVD to check the files, the sound is WAY off! I can click on the scene that I created and it starts from there just fine, but the sound is still a few minutes back in the movie. Any ideas on what's going on???
Duran
Ulead DVD MovieFactory 2 demands clean MPEG source files.
1. How did you obtain your SOURCE files?
2. What are their properties?
For example, when I extract the raw MPEG-2 video from the DVD-RAM disc used in my Panasonic VDR-M30 camcorder, the properties of the extracted MPEG-2 are as follows:
NTSC drop frame (29.97 fps)
MPEG files
24 Bits, 704 x 480, 29.97 fps
Field Order B
(DVD-NTSC), 4 : 3
Video data rate: Variable (Max. 8800 kbps)
Audio data rate: 256 kbps
MPEG audio layer 2, 48 KHz, Stereo
I am able to see these properties after I import the MPEG into Ulead DVD MovieFactory 2 and then right mouse click on the file and then click MEDIA CLIP PROPERTIES.
This is my cue.
It tells me what my Ulead DVD MovieFactory 2 project settings should be.
So I set my project settings to precisely *match* my SOURCE file attributes.
This is key.
What are the attributes of your SOURCE files?
Are they DVD compliant?
Have you set your Ulead DVD MovieFactory 2 project settings to match?
Jerry Jones
http://www.jonesgroup.net -
By the way...
You can access FIELD ORDER options by activating the ADVANCE MPEG
encoding options in Ulead DVD MovieFactory 2.
On my Windows 2000 computer...
1. I clicked MY COMPUTER;
2. I clicked my C: drive;
3. I clicked the DOCUMENTS & SETTINGS folder;
4. I clicked the ALL USERS folder;
5. I clicked TOOLS > FOLDER OPTIONS and then clicked the VIEW tab to
make sure Windows would show HIDDEN FILES AND FOLDERS;
6. I clicked the APPLICATION DATA folder;
7. I clicked the ULEAD SYSTEMS folder;
8. I clicked the ULEAD DVD MOVIEFACTORY folder;
9. I clicked the 2.01 folder;
10. I clicked the DVDMF i-n-i file and then typed ADVANCE=1 under the
[VIODRIVER] heading;
11. I saved the i-n-i file;
12. Then I closed Ulead DVD MovieFactory 2 and re-opened the program.
Now when I enter the project settings, I see a new ADVANCE button
under the COMPRESSION tab.
When the ADVANCE menu pop-up appears, click the BASIC settings tab.
You'll note a drop-down list that allows you to choose...
1. NO FIELDS
2. UPPER FIELD FIRST
3. LOWER FIELD FIRST
Hope this helps,
Jerry Jones
Ulead DVD Movie Factory 6 Plus
By orientaldragon in forum Newbie / General discussionsReplies: 8Last Post: 2nd Apr 2011, 08:48 -
By Ragamuffin in forum Authoring (DVD)Replies: 3Last Post: 6th Oct 2009, 12:22 -
Ulead DVD Movie Factory...
By mmitchell_houston in forum Authoring (VCD/SVCD)Replies: 225Last Post: 23rd Oct 2007, 10:59 -
By koberulz in forum Newbie / General discussionsReplies: 10Last Post: 26th Jun 2007, 07:14 -
Ulead DVD Movie Factory 5 Plus Help
By sootylfc in forum Authoring (DVD)Replies: 3Last Post: 21st May 2007, 18:20
