I purchased a Dazzle DVC (analog to digital) before I realized the all of the audio video problems it has when capturing from composite inputs. One of the most annoying problems is that it almost always looses the horizontal sync such that when I the top of the screen shows up on the bottom of the screen. However, sometimes this is the only problem with the capture & it is otherwise usable.
My question is how can I edit out the bottom portion of the screen (preferably after I convert it to mpeg) and then reconvert the resolution so it is still a VCD compliant mpeg. I heard this can be done with TMPEG but I haven't been able to figure it out.
Thanks in advance.
yes, tmpegenc has an option to crop your input file. you will have to load your video, select "settings" and then go to "advanced". select the "clip frame" option (double click)and adjust the cropping until the image is properly cropped. note: this will still give you a vcd compliant stream since you are still encoding to a vcd resolution (352x240 ntsc or 352x288 pal).
if you have to crop too much video and (with resize image selected) your image looks stretched, then you can try instead to use the masking option (under the same settings page).
XviD Encoded videos present distorted bar at the bottom
By deadp0et in forum Video ConversionReplies: 11Last Post: 4th Jul 2015, 09:45 -
Green Bar at bottom problem solved!
By DeniseAck in forum Capturing and VCRReplies: 0Last Post: 9th Aug 2011, 19:19 -
Black bar on bottom of Windows Media Player 11
By Jynx980 in forum Software PlayingReplies: 2Last Post: 1st Nov 2009, 11:58 -
Capture analogue with 720x576 has tiny horizontal bar at bottom
By ManUtdFans in forum Capturing and VCRReplies: 15Last Post: 21st Jan 2009, 14:12 -
Green bar on bottom and right side of divx movie
By gthorley in forum Software PlayingReplies: 2Last Post: 19th Aug 2007, 15:39
