Hi all
I'm authoring a DVD with IfoEdit because I wanted to include spanish subtities in LOTR extended Z1. I selected the video, audio and subtitles to created a DVD.
What I want is to keep the original structure but include another subtitle, don't know if IfoEdit can do it or I neer another program
Thanks in advance
Not the extended version Z1 ( NTSC). The Z2 has spanish audio and subtitles, but it's PAL
There is no Z4 (SouthAmerica) release for the extended version. -
By include another language you mean you want to ADD a NEW subtitle stream to DVD? Or do you mean you want to retain ONLY one subtitle stream.
I can tell you how to do either (the latter is easier than the former thou
Looks like he wants to rip a subtitle stream from the Zone2 release and splice it into the Zone1 release.
- Gurm -
Ok, so you want to create a new DVD with the Spanish subs but retain the original menu. You can do that BUT REMEMBER that the original menu DID NOT have an option to select spanish subtitles. That means that even if you retain the original menu it won't work/look right.
You can enable the subs manually with your remote (easy). Once you re-author the necessary VTS you can re-intergrate it into the source VOBs with IFOUpdate.
OR you have to edit the original menu to include the option to select spanish subs. Now that's a much bigger project
You have two choices replace an existing subtitle stream with the spanish stream and let the menu have the wrong name. Re-generate the menu and edit to have the option to select spanish subs.
Guide for extracting menus for editing, and reinserting edited menus
By manono in forum Authoring (DVD)Replies: 167Last Post: 8th Dec 2022, 02:44 -
Want to copy Blu-Ray film only no menus, previews, ads, etc.
By jcikal in forum Newbie / General discussionsReplies: 2Last Post: 15th Sep 2010, 15:49 -
How do i copy dvds onto hard drive and what is best software to copy sav
By bfishwick in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2009, 17:29 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 07:26 -
Magix Movie Edit Pro Menus and Sub-menus
By gayclarke in forum Authoring (DVD)Replies: 8Last Post: 11th Aug 2007, 10:07
