Ok, plz ignore my earlier post regarding DVDXCOPY. I want to go a new way. I need to know what the best tools are to make a backup of a dvd. I burn with a DVD+R/RW drive so I am going to end up burning to DVD+R discs. What tools/software do I need and which guide is it on dvdrhelp. I have been looking but can't find exactly what I am looking for.
Thanks,
G-man
It doesnt matter whether its a DVD+R/W or DVD-R/RW. You still use the same tools.
For DVD5>DVD5
http://www.doom9.org/mpg/dvd5-backup.htm
For DVD9>DVD5
https://www.videohelp.com/forum/userguides/129990.php
Both of which were in the guides section. ALWAYS check there before you post here.
Can't Backup TV Recorded To DVD-R Discs
By pejayuk in forum Newbie / General discussionsReplies: 5Last Post: 17th Jan 2011, 19:11 -
Looking for the Best Way to Backup DVD Movies and store on Computer HD
By jet757f in forum DVD RippingReplies: 2Last Post: 31st Aug 2010, 21:39 -
What do you think is the best and fastest software to backup Blu-ray discs?
By WPlotkin in forum Blu-ray RippingReplies: 9Last Post: 28th Oct 2009, 12:17 -
burning and playing blu ray/hd content onto discs onto dual layer discs
By julie_152 in forum Authoring (Blu-ray)Replies: 18Last Post: 21st Sep 2009, 14:36 -
Is copying gaming discs same as copy DVD/CD discs?
By coody in forum ComputerReplies: 24Last Post: 10th Jan 2009, 23:29
