Hello!!!!!!
I was advised to use Goldwave to fix my Audio problem.
I load the AVI/XVid movie into Goldwave and then once fully loaded I click on the "effects" tab and click on volume then maximise. It does a scan and all is ok. However....when finished it brings up a box with new levels etc...when I press OK...my system freezes and crashes...The next step is to the save the new maximised audio file...but I never get this far. What do i do???
Do I have to change those settings within the box....or what?
I have pressed cancel within this box & saved the file.....but the eventual new file still has LOW LEVEL AUDIO ???...No different to the original file.
Please Help !!!
MLOR.![]()
Results 1 to 1 of 1
Hi8 -> DV -> Final Cut Pro = Low, low audio levels in captured video
By xmiller in forum Capturing and VCRReplies: 12Last Post: 14th Dec 2010, 17:59 -
AC3 audio distortion and levels.
By hardhatmac in forum Authoring (DVD)Replies: 1Last Post: 19th Mar 2010, 19:39 -
tool to view audio levels
By tb582 in forum MacReplies: 0Last Post: 2nd Feb 2010, 10:18 -
How to get two audio levels the same
By TolleyM in forum AudioReplies: 1Last Post: 20th Oct 2008, 10:38 -
At wits end - Capturing with ADVC-100 and audio levels are extremely low
By Towncrier in forum Capturing and VCRReplies: 13Last Post: 18th Sep 2007, 19:04
