Hello!!!!!!
I took the earlier advice to use Goldwave to Maximise Volume.
I load the AVI/XVid movie into Goldwave and then once fully loaded I click on the "effects" tab and click on volume then maximise. It does a scan and all is ok. However....when finished it brings up a box with new levels etc...when I press OK...my system freezes and crashes...The next step is to the save the new maximised audio file...but I never get this far. What do i do???
Do I have to change those settings within the box....or what?
I have pressed cancel within this box & saved the file.....but the eventual new file still has LOW LEVEL AUDIO ???...No different to the original file.
Please Help !!!
MLOR.![]()
don't hit ok. simply save your work when you close it.
Or, hit copy 2 button at top of window, this will create a new file that is the louder one, while leaving the old one as is.
Not sure why your audio is low level, but goldwave is great stuff once you learn it.
Jeff
Need suggestions from pros on how to process low-level audio
By Asterra in forum AudioReplies: 2Last Post: 1st Jul 2011, 19:57 -
FFDshow audio decoder level is way too low...
By MidnightMike in forum AudioReplies: 2Last Post: 4th Dec 2010, 00:34 -
Need help with low level hum (audio attached)
By sdsumike619 in forum AudioReplies: 10Last Post: 22nd Aug 2010, 02:34 -
Philips DVP5992/37 plays WMV Main Profile (Low Level)
By edDV in forum DVD & Blu-ray PlayersReplies: 4Last Post: 13th Dec 2008, 17:52 -
MP3 track - low voice level
By Digiface in forum AudioReplies: 5Last Post: 30th Jul 2007, 17:05
