Hello!
I was just wondering if there is any way to putt a film as long as star wars (over 2 hours) on a regular dvd-r?????
Yes, it is possible, but you will need to either transcode or reencode. Check out the tools section to the left for programs that can do this for you. DVDShrink would probably be your best bet because it's free, but there are lots of progs that can do this. To fit it, you'll have to sacrifice some quality, but such are the laws that govern our universe
if you are capturing yourself (like from VHS or Laserdisc), when you go to encode to mpeg-2, make sure you check the Bitrate Calculator in the Tools section here, and select a bitrate that will give you a file size that will fit on a dvdr.
- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light"
help with star wars saga br
By kn5150 in forum Blu-ray RippingReplies: 9Last Post: 21st Sep 2011, 16:55 -
Edit Video Like in Star Wars ?
By SEJedi in forum EditingReplies: 15Last Post: 28th Apr 2011, 09:50 -
Star Wars 3D
By stiltman in forum Off topicReplies: 20Last Post: 26th Oct 2010, 19:11 -
Original Star Wars Limited edition dvd not anamorphic. How would I convert
By shroomalistic in forum Authoring (DVD)Replies: 46Last Post: 21st Aug 2009, 21:13 -
Spike HD users - is Star Wars ever in 5.1????
By yoda313 in forum Off topicReplies: 9Last Post: 18th Aug 2009, 19:56
