Okay, thanks for the input! After reading those comments I am really afraid to open the box and install it! I am trying to put together a gift and only have two weeks to do it! I have all of my still photos and music lined up, scanned, altered, etc and ready to make a movie on dvd that will place on any DVD player (if possible)! I don't have months for working out problems and getting any more frustrated than I am now! Ha! Can anyone suggest a good "right out of the box" easy software that will accomplish what I want to do? I would like some fancy transitions, and be able to cut up music in the video. What seems to be the best for a beginner? Any tips would be appreciated!!!!!
Thanks,
Tina![]()
I've been using Studio 8 for about 6 months and I like it better than anything else I've tried. There are many (here) who don't like it, but I found it easy to use and workable although it does have some problems.
The biggest problem I had was hang-ups when trying to render a project. I eliminated most of those hangups- after editing I rerender the entire project into a one new avi file, then load that file (add menus if needed) and then render it. -
dont know about fancy transistions and cutting audio, but if you want no brainer software, try Movie Factory 2. It works great and will let you do a number of things that it sounds like you are wanting to do.
I also think that spruce ups (MyDVD) is pretty easy to use and does more nifty motion stuff over MF2 right out of the box. -
Pinnacle's Studio is perhaps a good choice.
I haven't tried it myself but a friend who is afraid 8) of what I'm doing has been able to make a terrific holliday video in two days (including capture and encoding). I think this qualifies as out of the box.The more I learn, the more I come to realize how little it is I know. -
I have used both Pinnacle Studio 8 and Ulead Movie Factory 2. I have found it easiest to use Studio, however I get more bang for the Buck using Movie Factory. I have made a few dvd's for my Family and they prefer the ones I have done with Ulead over Studio.
[/quote]I have made a few dvd's for my Family and they prefer the ones I have done with Ulead over Studio.
What exactly do they prefer? Is the picture quality noticably better? Or something else? -
I second, rahter third or fourth, Pinnalce Studio. My 8.6 version gets many errors where I have to restart Studio, but the finished product is worth it.
Need recommended software to edit videos and create a DVD
By OM2 in forum Newbie / General discussionsReplies: 4Last Post: 14th Feb 2011, 12:09 -
What software can create AVCHD DVD?
By cheerful in forum Newbie / General discussionsReplies: 9Last Post: 21st Dec 2010, 14:54 -
Need software to create training videos.
By mlong30 in forum Video Streaming DownloadingReplies: 1Last Post: 2nd Dec 2010, 11:19 -
What is your favorite Blu Ray software to create a DVD???
By Endoking01 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 7th Jun 2010, 20:43 -
Anybody know what software was used to create this video?
By daiweb in forum EditingReplies: 15Last Post: 18th May 2009, 12:19
