My A05 is connected to the 1st IDE controller as Master. My Samsung DVD ROM is connected to the 2nd IDE controller as Master. Nothing else is on IDE controllers. My HD are scsi. I am running XP and fixed the IDE speed dropping problem from DMA to PIO mode. DVD-ROM ripps ok when it was in the PIO mode(1.9x) But when I enable DMA and starts to ripp at 4.5x, my system hangs. Do I need a special cable like ATA66 or UDMA cable? I can't think of what could cause the hange except data is transferring faster than the cable can handle. Any other ideas? Oh, this is not related to one movie only, it's all movies when it's ripping at speed higher than 2.5x with DVD Decrypter.![]()
Hey nooner' ,
Im not an IDE expert but I think that you may need an 80pin IDE cable. Do yuu use ATA66, ATA100, or ATA133 drives? , because I believe that anything above ATA66 requires a 80 pin connector cable. -
Interesting handle. So you are undefined? In any case, my DVD-ROM has the 40 pin interface. I may need to try the EIDE cable and see if that helps.
Fast/reliable drive just for ripping?
By wetcamelfood in forum Newbie / General discussionsReplies: 4Last Post: 11th Nov 2011, 01:07 -
BD Rebuilder hangs and shuts down system
By Mark AL in forum Blu-ray RippingReplies: 3Last Post: 7th Feb 2011, 08:43 -
Recommend fast & small (few system resources) DVD utilities quick analysis?
By MISS CHIEVOUS in forum Newbie / General discussionsReplies: 0Last Post: 4th Jul 2010, 15:37 -
who is here from uk and is a ripping expert
By lóreal in forum Off topicReplies: 7Last Post: 21st Mar 2008, 19:23 -
Need a fast ripping dvd burner with lightscribe
By hellbringer in forum DVD & Blu-ray WritersReplies: 7Last Post: 13th Nov 2007, 20:46
