Hi,
I am trying to convert some AVI's I have downloaded with CC SP 2.62 when I press encode I get this message:
Read only 0 bytes, while expecting 8 bytes.
I can get CC to work with some AVI's that I have but not the ones I really need to use.
I have noticed other people have had this problem but have not noticed any saying they have solved it.
<font size=-1>[ This Message was edited by: Newbie1 on 2001-09-30 10:53:01 ]</font>
The reason why that error occurs is because the CRC Check failed. There's a 'CRC Crack Removal' available on the net. People says it works, but there are occassional video problems. I remember another topic about this 'CRC Crack Removal' but can't remember which. =|
This has worked thanks, but I now have this error:
couldn't find appropriate video codec for div3.
<font size=-1>[ This Message was edited by: Newbie1 on 2001-09-30 11:20:50 ]</font> -
It sounds like you're trying to open a DiVX.avi. Depending on how the DiVX was originally encoded CCE may not be able to open it.
You also might just need to install the DiVX codecs on your PC. -
You can re-encode it but you'll kill the quality. Try opening the avi with TMPGEnc and see if that works.
Cinema Craft Encoder Sp 2.67.00.27
By Gwar in forum Video ConversionReplies: 1Last Post: 19th Feb 2012, 11:32 -
Problem with Cinema Craft Encoder SP and Windows 7
By echo1434 in forum Video ConversionReplies: 6Last Post: 24th Dec 2011, 16:51 -
GOP questions in Cinema Craft Basic v2.7
By schrakapouet in forum Video ConversionReplies: 3Last Post: 22nd Aug 2008, 13:54 -
Help with Cinema Craft Encoder
By Topcat360 in forum Video ConversionReplies: 31Last Post: 29th Jan 2008, 16:51 -
Cinema Craft Encoder Plugin
By MI6 in forum Video ConversionReplies: 1Last Post: 11th Aug 2007, 18:05
