  1. I am trying to create a VCD with Adobe Premiere 6.5. The Problem is that when i create it the only thing which functions is the pictures. ie there is no sound.
    I am new to Adobe Premiere 6.5 and I have this problem. Could you help me please?
  2. O.k...on your timeline you should have Video on the top and Audio underneath....when you scrub the time line can you hear Audio in Premiere?
    If you can then when you are exporting, you are not exporting the Audio...only Audio. How are you capturing the video? Are you using the Mainconcept encoder to encode?
