I am trying to author a DVD using IfoEdit. I followed one of the guides and have run into a problem. IfoEdit only accepts one m2v file for the video stream and one AC3 file for each audio stream.
I demuxed the audio and video using DVD Decrypter, but I have three seperate m2v files and three AC3 files. What is a good way to join the m2v's together and the AC3 files together to create one file for both streams? Thanks.
Results 1 to 9 of 9
"Can You Dig It!"
After some research it looks like I have to convert the AC3 files to a WAV with a program called BeSweet and then join the WAV files together. OK how do I do that
What's a good WAV joiner/editor to use?"Can You Dig It!" -
VOBMerge is my favorite merger. It'll merge anything - including m2v's and ac3's.
And you do not want to convert that ac3 file to a wav file. AC3 is a better format, and IFOEdit will read AC3 files, so don't waste your time and sound quality converting it.
Be aware that unless you're on a NTFS file system, your file sizes will be limited to 4GB. That may not be quite enough, depending on your movie. If you have Windows 2000 or XP, you're probably on a NTFS file system, and thus shouldn't have to worry.
If you aren't on a NTFS, let me know, and I can give you a work-around. -
You can join wavs using a free app called Add-a-wav. There are others too.
Darryl -
Thanks KetchsumAir. That's what I am looking for. I hate to have to convert-join-convert back files if it isn't necessary.
Well, I am using WinXP on a FAT32Originally Posted by KetchSumAir
which may not make things easier. The DVD is only 2.3GB, so i may not have a problem now but I might run into problems later.
"Can You Dig It!" -
Just found VobMerge 2.1. It wil allow you to create files > 4GB.
http://www.angelfire.com/nc/evilmastr/
Thanks for the help guys."Can You Dig It!" -
VOBMerge allows it IF your file system will accept it.
Yours will not. Believe me, you'll end up with all kinds of strange errors - but you won't be able to create a file bigger than 4GB on anything but NTFS.
For bigger files, I'd suggest running through IFOEdit twice with smaller files, then re-combining the results (resultant VOB files all at 1GB or less by default) into one DVD, if the result is less than 4.38GB (the DVD-R limit). The only gotcha with this approach is you will have trouble with the AC3 file - if you use a simple cutter, it won't put a header on the resultant cut file, and IFOEdit won't read it in correctly. TMPG will automatically put headers on files it cuts, but I don't think it'll cut a file w/the AC3 format....not sure what program will do this correctly, but there're gotta be one (I don't have this problem - I have NTFS....maybe you should think about updating to NTFS???). -
I'm a intermediate user when it comes to PC's, so I don't know if my next questions is plausible. My HD is partitioned into two parts. I use the C: drive for programs, etc. and the D: drive for "working space". Can I format one partition differently than the other (ie NTFS)?Originally Posted by KetchSumAir"Can You Dig It!"
Yes! Great thinking to partition. I *believe* it's as simple as right-clicking the D: drive, and selecting the format option. I've never done it this way as I've always done it as I install the operating system, but I believe it should work.Originally Posted by bigb_y2g
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 07:36 -
How to add audio(.mp3) & adjust in video(.mkv) & burn in vbo ?
By ashe09 in forum AudioReplies: 0Last Post: 16th Jul 2011, 04:06 -
Video + mono -> Video + Left & Right audio dubbing
By mmafan in forum Newbie / General discussionsReplies: 7Last Post: 17th May 2010, 18:35 -
ASF2VC1 & transcode the audio WMA to AC3, then mux video VC-1 and audio
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 9th Jan 2010, 09:02 -
How Do Take The Video & Audio Off Of My Computer & Put It On A TV?
By Ghettorapboy7 in forum Newbie / General discussionsReplies: 4Last Post: 30th May 2007, 11:25
