hi you knowlegable people.
When I try to convert an extracted AC3 file to WAV I get a "Bad Syncword" error. I am suspectimg the AC3 is corrupted.
I downloaded BeSplit to fix the AC3 file. However I am confused as to the command I need to type to fix it. I went through the examples.txt file and can't seem to find the right command with the switches.
Can anyone please help me?
i have this problem too, gives me that error in headac3e . I dont know wat to do ,some say run it through ac3fix but mine says it cant read it.
Use BeSplit. I did it yesterday to fix the extracted AC3 file. Then used headac3e to convert to a wav file.
Hi,
You might wanna use ac3tool from the tools section on this site. Here's the link:
https://www.videohelp.com/tools?tool=128#comments
Did not try this one myself (yet), but it looks like a clever tool.
Frank -
If you convert ac3 to wav do you not loose the 5.1 sound? I've tried to demux the ac3 using VirtualDubMod & then run it though ac3fix or Besliced, but I can't seem to work either of these programs, even when someone has given me clear instructions
How to use BeSweet or azidts to convert dts wav to mono wav?
By tcwillghsh in forum AudioReplies: 22Last Post: 28th Aug 2012, 13:36 -
How to convert WAV/MPA/MP3 audio to AC3(DD) using Besweet
By Baldrick in forum User guidesReplies: 89Last Post: 11th Aug 2012, 16:14 -
How to convert WAV/MPA/MP3 to AC3 6 channels?
By katalogas in forum AudioReplies: 8Last Post: 16th Feb 2010, 14:12 -
how can we convert ac3 to wav?
By sumeshkri in forum AudioReplies: 6Last Post: 4th Sep 2008, 02:29 -
Convert 2.05gb wav to AC3
By colt4523 in forum AudioReplies: 7Last Post: 15th Nov 2007, 06:28
