Is it possible to cut off (like in Vdub) ads (certain period of times) from PVA streams and then join the cutted pieces into one again to reencode it by DVD2SVCD into SVCD? It's important that this tool can't be buggy - fully compliant with standards (synth issues).
I want to do it by DVD2SVCD because I have heard that it's faster because it works in YUV mode, and VirtualDub works in RGB mode.
Thx for any suggestions.
Regards,
Patryk.
Guess im a noob, whats a PVA stream?
Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
No need to post this quetion in so many forums.
Ejoc's CVD Page:
DVD:
Capture:
Ejoc: no noob - PVA is used (mostly or only, don't know) by DVB systems, so it is quite specific.
I would suggest You to put Your stream first through PVAStrumento to fix droped frames and sync issues and then use any tool/method for MPEG editing, You like.
Cutting videos without re-encoding?
By TYLER08027 in forum EditingReplies: 3Last Post: 18th Feb 2011, 22:14 -
New experimental TS cutting software for MPEG-2 and H.264 Transport Streams
By Nukster in forum EditingReplies: 2Last Post: 14th May 2009, 09:16 -
Cutting and Pasting Hi Def Transfer Streams in Native Resolution
By Jcage89 in forum EditingReplies: 6Last Post: 21st Aug 2008, 12:17 -
encoding MPEG2 transport streams at 1920x1080 with very specific parameters
By duffbeer911 in forum Video ConversionReplies: 17Last Post: 16th May 2008, 13:46 -
Cutting AVI without all the re-encoding
By gameroftheuk in forum EditingReplies: 6Last Post: 31st Aug 2007, 22:13
