I am trying to configure my system so that I can play back multichanel and AC3-DivX-Movies and DVDs (VCDs & SVCDs) properly. I am using Windows XP with Media Player 9.0. But I have the following problem:
Windows Media Player offers me the possibility to activate the SPDIF-Out of my soundcard (Hoontech Yamaha Digital XG with Driver 5244), which I want to use with my digital sourround-receiver. But the SPDIF-Out only stays activated as long as there is no AC3-Sound in the DVD (e.g. during the DVD-Menu). As soon as AC3-Sound begins, Media Player does automatically switch back to "Stereo". When I then manually select "SPDIF-Out" I get no sound anymore until I switch back again to "stereo".
After I now installed WinDVD 5 and activated SPDIF-Out in this Software, I was able to activate the SPDIF-Out in Windows Media Player 9 so that it would remain activated during AC3-Playback. The Sound-Option-Dialog in Windows Media Player now shows the "Intervideo"-Logo so it seems it somehow was modified by the installation of WinDVD. I still have to activate the SPDIF-Out in Windows Media Player each time I start a DVD, but anyway it works right now. So far so good.
The only problem is, that since the Installation of WinDVD, which seemed to solve the SPDIF-Problem, I do get "distorted sound" when I now try to play multichanel or AC3-DivX-Movies with Windows Media Player or WinDVD itself. The sound is full of "digital effects" then (like playing a data-cd in a cd-player) and Media Player or WinDVD crash after a few seconds of playing.
So it seems the intervideo audio-codec (?) that was installed with WinDVD and that solved my SPDIF-Problem is not compatible with multichanel or AC3-DivX-Movies.
Is there no way I can play back both: multichanel DivX and AC3-DVDs with SPDIF-Out ? Anyone who knows a solution ?
Thanx in advance!
Fantastic
Results 1 to 1 of 1
Audio Sound Distorted
By Teac23 in forum Software PlayingReplies: 0Last Post: 1st Aug 2010, 07:40 -
Intensity Shuttle Installion Problems
By seiferx in forum Capturing and VCRReplies: 4Last Post: 21st Jul 2010, 17:45 -
REQ : - SOUND Distorted from footage
By mojoeuk in forum EditingReplies: 2Last Post: 23rd Nov 2007, 14:54 -
Distorted sound
By SE14man in forum Newbie / General discussionsReplies: 5Last Post: 17th Oct 2007, 18:40 -
distorted sound
By phillyrider in forum Newbie / General discussionsReplies: 3Last Post: 24th Jul 2007, 06:25
