  1. When not using the wizard in TMPGenc - trying to get rid of the 1600kb minimum setting, how can i tell how long the movie is going to be by changing the bitrate.
    Cos it tells you in the wizard.??
    Jan 2002
    You need to use a bitrate calculator before you start encoding. You can find them in the tools section.
  3. Cheers - I thought that would be the answer...
    I was hoping for a quicker way like in the wizard that I just hadn't noticed.
