I have converted a lot of video with Snazzi's VCD creator w/o problem except this one.
A lot of problematic frame as shown below contained in the captured video although it play well in the VCR.
Sorry about that.
Here is the image:
[img]https://www.videohelp.com/forum/images/guides/p608897/test.jpg -
You need to type this
Where the hell did all that come from I only typed test.jpg inside the image tags and when I previewed the post it only said test.jpg.
Very strange. -
That's an interesting shot. It looks like your vertical sync is out of whack. I don't think there's a software solution. It's the capture equivalent of vertical roll on a TV, happens now and then? Your tape player may need cleaning, or it's just a bad tape (did it get hot or wet?). You can try amplifying the signal (video or rf amplifier, depending on your settup). Dont' de-interlace on capture, and check your field order. If it plays fine on the VCR, then it really sounds like your capture card doesn't like marginal video (it looks very marginal from the screen shot, tape wise).
To Be, Or, Not To Be, That, Is The Gazorgan Plan
Problematic interlaced source (missing/dupped fields)
By Dogway in forum RestorationReplies: 6Last Post: 4th Feb 2012, 20:19 -
How to Make ( problematic or something) DVD Seekable?
By devilcoelhodog in forum Authoring (DVD)Replies: 0Last Post: 18th Sep 2009, 20:55 -
How to convert problematic video file?
By gtracs in forum MacReplies: 5Last Post: 3rd Aug 2009, 23:32 -
Problematic mpeg2 file
By Caple in forum Video ConversionReplies: 3Last Post: 4th May 2009, 19:03
