  1. Hello,
    any encoding software does exist for unix (not necessarly LINUX)
    so that I can be able to convert a divx to dvd compliant ?
    I have a very powerful XP1000 (alpha) with FreeBSD and it would be
    just great to being able to use it to convert from divx to dvd (mpeg2 dvd compliant file).
    thanks
    oic
    Apr 2003
    check out the trasnscode program url: http://www.theorie.physik.uni-goettingen.de/~ostreich/transcode/
    which is a command line program. The gui for it would be kavi2svcd url:
    http://www.cornelinux.de/linux/kavi2svcd/index-english.html
    I've been using these program to encode Stargate I dl and put them on cd. I've also used them to create generic mgp2 so that the the U-Lead movie factory will create an ISO which I can then mount them as an hardrive to check before using the Linux XCDROAST program to burn them.
  3. Originally Posted by courtrrb
    You DL'd a movie!
    My AVI -> Any Format Guide is available here.
    My Frame Resize Calculator (enhanced for Virtualdub) is available here
    Apr 2003
    The tv series not the movie and I bought it. As soon as they come out on dvd I replace the ones I recoreded.
  5. Originally Posted by courtrrb
    Oh, ok,
    Apr 2003
    Ha ha I don't even need to dl them or anything else now! I finaly got the capture working in Linux. I've been recording them of satalite now. I tried cable but the picture qualty was terrable.
