i have wasted a ton of cds trying to get nero to burn my svcds...all atempts have failed.
im trying to create menus for my svcds so i follow the "How to make a SVCD including a menu with Nero 5.5+" guide, but when i go and play it in my apex 600a, i get nothing. even burning a single svcd movie doesnt work. however, everything burns and plays fine if i use vcdimager. problem w/vcdimager is that you cant make menus.
so can someone tell me what im doing wrong? or suggest another method/program i should try.
-tia
edit: im using nero version 5.5.0.3...could this be my problem?
<font size=-1>[ This Message was edited by: spr1nt on 2001-07-08 15:33:03 ]</font>
Results 1 to 10 of 10
I found that the only versions of Nero that worked with menus on most DVD Players were Version 5.5.1.8 (+bugfix) or the complete version 5.5.2.3
As the Nero website only offer ther version 5.5.2.4 to download try this one first. If it still doesn't work email me, and I'll pass on the version 5.5.2.3. (which you can install over 5.5.2.4) to you. -
First off, it's insane to waste cd-r's when you can use
cd-rw's for your testing.
Have you tried playing the finished product in a software dvd player such as power dvd. Maybe it is the apex that has a flaw.
You can get the power dvd demo at their site. -
Wait! Let's be fair to the Nero (ahead) people. I've had great success burning both VCDs and SVCDs with Nero, which I LOVE.
On 2001-07-08 17:58:04, Greg12 wrote:
I hate nero.
I have never made a successful VCD/SVCD
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE> -
First of all check that your player can support VCD menus becuz a lot of them cant.
Second if it can then make sure you have PBC on.
Lastly, check what cd's you are using because i have made plenty of (S)VCDS in nero with only one out of every about 30 screwing up. -
I've been able to create VCDs with menu's from Nero 5.5.2.4 with no problems. My Sony DVP-S360 doesn't support SVCD so I can't test that.
All I can say is, DON'T use version 5.5.0.3
It's only good for producing coasters.
Try 5.5.2.4 for good results.
that's absolutely true. that version doens not only produce a lot of waste it also crashed my system several times. -
I HAD THE SAME PROBLEM WITH NEROS LATEST VERSION UNTIL I FOUND OUT THE IT WAS THE CD'S THAT WERE CAUSING THE PROBLEM.
I CANNOT RECORD A SVCD ON DIGITALMEDIA RW/CD'S BUT IT WORKS GREAT ON IMATION RW/CD'S. I NOW USE IMATION WITH NO PROBLEMS.
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 19:49 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 19:23 -
Can I install both Nero 8 & Nero 6 on same machine?
By OzarkBaby in forum Newbie / General discussionsReplies: 8Last Post: 3rd Jan 2008, 21:09 -
need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)
By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 11:10 -
Nero Recode/Nero Digital users...
By siratfus in forum Video ConversionReplies: 4Last Post: 31st May 2007, 05:06
