Dang........I could have sworn that I posted this already......but here goes again.
Here's the deal......I need to be able to burn multiple cd's at once. Currently I have one CD burner, one CD drive that will be upgraded to a CD burner, and one empty bay that will be getting a DVD burner that can burn CD's.
My question is if there is a program/method that would allow me to burn on all three drives at the same time, allowing me to burn 3 cd's at once.
Any help/comments would be greatly appreciated. THANKS!!!
-Nate
I believe Nero has this feature. I am using an old version though so you might want to check that the current version has it (anyone confirm?).
Originally Posted by natebetween
nero/feurio/discjuggler
the only problem is that you need to have scsi/firewire drives for it to work.. ide isnt fast enough and something about ide not being able to send/recieve data as good as scsi/firewire.. asychronus or something. -
I have the latest Nero 5.5 and 4 DVD burners, only 2 of which are FireWire, and regularly burn DVDs to all 4. CDs are all the easier because they usually require a smaller transfer rate. EIDE is plenty fast for burning to multiple drives, though I don't have optical drives on the same IDE channel which may or may not make a difference. And considering that most FireWire drives convert to IDE for the drive interface it certainly isn't faster than IDE inside your own computer
burning multiple mp4 files to DVD format
By dvdnewbie64 in forum Newbie / General discussionsReplies: 2Last Post: 20th Mar 2009, 13:59 -
Burning 1000's of files to multiple dvd's
By lordhutt in forum ComputerReplies: 12Last Post: 14th Dec 2008, 15:45 -
Burning multiple .MDF files to DVD
By henry13 in forum MacReplies: 10Last Post: 26th Jan 2008, 13:01 -
Burning Multiple AVI's with Menu
By Candoo in forum Authoring (DVD)Replies: 12Last Post: 8th Jan 2008, 17:52 -
Help burning multiple 8cm DVD+RW from Camcorder to 12cmDVD+RW
By WOWSY in forum Newbie / General discussionsReplies: 0Last Post: 3rd Jul 2007, 13:48
