I was very sceptical using a 30 ft cable, so I did try it with a normal 3 ft. to compare, but I could not see any difference and both look very good to me. Much better than using RCA (whatever the lenght) feeding the AIW with a composite signal.
Results 61 to 74 of 74
This is strange to me: how can one get a better signal from the same source without active components?
I may be stupid, but how can a S-Video signal (matter of fact: 2 signals) be generated from a composite source?And even if you can do that with passive filters/splitters: how can that signal be better that the original signal? -
Hi Dragonsf
I am not saying that the signal is better.
What I am trying to point out, is that the "active" transformation in my ATI AIW Radeon is doing such a bad job, that doing it passively before it is beeing fed into the AIW is much to be preferred.
I found this out by coincident when I connected my AIW to my S-video VCR and found that the picture on my comp whas much sharper (even if the VCR was fed a composite signal). I just stumbled accross the little converter when I was buying some audio cables, and even if it said S-video to RCA, I spent $4 to try it as a RCA to S-video.
For all I know it might be doing nothing more than feeding the same signal to both color and luminisance (like a simple Y-splitter) in the S-video cable, but I don't care as long as it works -
so guys which adapter should i get? should i just go to radio shack and ask for a RCA to S-video Minijack? what should i ask them for. please help. thanks.
i use 25 feet myselfOriginally Posted by abrakadabra
they put thicker wire in it
as resistance is the only factor
the 25 foot is actually better than the cheap 3 feets that they make -
I don't know how you guys can be having trouble finding 6 foot s-vid cables.
Every KMart and WalMart carry them in their TV Dish department, 3 and 6 foot, maybe 12, usually Magnavox or RCA brand.
I bought a 12 in my local shop, 3.99, didn't cut it to see the guage of the wire, total is near a 1/4 inch diameter.
The unit in the Shack url above is a female-female, so you'd have 4 connections, each of which will provide resistance and possible signal loss. -
@ everyone
where can i find cable that has a composite yellow for my VCR on one side and an S-video male on the other side for a reasonable price. or is there like an adapter that has a yellow female on one side and a s-vdeo male on the other, where can i find them for a reasonable price. i would prefer the first choice, but remember keeping the price in mind. thanks. -
@ skip2mypoo
This here is a link to where you can edit your profile.
Scroll down a little and you can put in your Computer Details for everyone. Use the link or click Profile at tetop of the page. -
@ funkguy3.5
LOL LOL at the way you address me.
i filled out most of my profile, pleae tell me what u think. -
Get the adaptor. I bought a few of these at a computer show and they work both ways. If needed, I could post a pic here showing you my setup. I bought a few of these because my Panasonic tv either accepts composite or S-Video so I have all of my older components connected to a switch box. For instance: my NES (nintendo), I have the composite yellow running into the adaptor and then a S-video running from the adaptor into the switchbox. I have the single mono audio cable from the NES into a double composite adaptor and then a regular red and white set of cables into the switchbox.
Price of composite to S-video cable: $39.99
Price of adaptor, 6 ft. s-video cable and composite audio: $28 (at most)
If you get lucky you could find some at a computer show or on ebay. There are some cheap ones on there sometimes. -
hey guys i bought something today so now i need somthing else. i bought a cable that has three cords: [1] white, [1] red, [1] s-video male, it looks like this:
http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&category%5Fname=CTLG%5F003%5...5Fid=15%2D1577
anyways now all i need is that audio adapter that i am getting and an S-Video to RCA adapter. so its basically the opposte now, any ideas where i can get one for cheap? -
@ funkboy2+2
i left them empty cuz i dont know how to find out what they are.
RCA composite video on Wii but component video and VGA inputs on tv
By shashgo in forum Newbie / General discussionsReplies: 3Last Post: 22nd Aug 2010, 22:48 -
What video cards support S-Video & Composite output over VGA via adapters?
By Bix in forum ComputerReplies: 5Last Post: 22nd May 2010, 22:57 -
Compatibility of composite video output VCR with component video input TV
By boshu22 in forum Newbie / General discussionsReplies: 7Last Post: 7th Sep 2009, 23:46 -
Canopus AceDVio composite capture problem (Svid works, but not composite)
By bfrandse in forum Capturing and VCRReplies: 3Last Post: 28th Oct 2008, 11:55 -
Composite IN vs S-Video IN (using converter wire composite to s-video)
By goal in forum Capturing and VCRReplies: 2Last Post: 29th Mar 2008, 22:19
..........Device Manager kinda says it right there....
