Can DVD Shrink Decrypt? If so then no need for DVD Decryptor.
In looking over the guides I came apon this:
DVD9 to DVD5 with DVD Shrink
+Very fast
+Free
+Built in DVD Decrypting
-No burning
-Can't set exact size
Here is the link.
https://www.videohelp.com/forum/userguides/141024.php
Results 1 to 13 of 13
YES, it does decrypt.
I copied Ice Age DVD just last night (first-time experience) from original DVD to a DVD-R, took me 40-45 mins from loading DVD to getting a copy.
I copied just the movie, no extras or menus. There was no compression involved thou. After I 'Backed up' the files onto harddrive, I used Nero Express (came with the drive) to burn.
P.S. I'm sort of a newbie too, just got my NEC ND-1300A the other day, Ica Age is the only DVD I have thou. -
yes, DVDshrink can decrypt...
but it's not the best at it...there are dedicated ripping proggies that have been revised many, many, many times over the years to become very, very good at ripping
i personally use DVDdecryptor to rip to the hdd first and then use DVDshrink to process it afterwards...
keep in mind, DVDshrink can NOT remove RCE, PUO, and (i believe) macrovision...
so, if you want any of those to be removed, you will have to use a dedicated ripping proggie like smartripper or dvddecryptor...both of which are completely FREE -
If DVD shrink can't decrypt it, will it warn you first? or just attempt to shrink decrypted video?
I also use DVD Decryptor but am trying to simplify my process.
- DVD Decryptor
- DVD Shrink
- Nero Express -
Originally Posted by MachineMan
cuz that's already pretty simple and straight-forward -
You can Definitely cut the middle man(dvd decryptor) and just use Shrink and Nero with no problems at all. I've backed up my whole DvD collection without any problems. The quality is exactly the same!!! I still don't understand why people use Decryptor when Shrink is just as good. And with the all the movies I've backed up I haven't come across one movie with RCE, PUO, or macrovision. So It's up to you whether you want to waste your time with Decryptor. Shrink will give you the exact same results and you'll get an error message if it can't decrypt a movie.
- RCE: you wouldn't notice because you're playing the DVDs in the region it was meant for. try taking a RCE protected region 1 DVD and playing it in a region 2 DVD-ROM. there may be problems.
also, if you leave the RCE in the DVD, then you will have a hard time playing your backup in another region.
- PUO: you definitely have enountered this....Prohibited User Operations. whenever you try to fast foward the FBI warning, but the DVD player doesn't allow you to...that's PUO. you can remove those restrictions w/ DVDdecryptor...DVDshrink can't
- Macrovision: not sure if DVDshrink has the ability to remove this or not...but assuming DVDshrink doesn't...you won't notice the problem unless you're recording the DVD through analog...if you don't remove, then your backups won't be able to be recorded through analog..(i.e. to VHS and/or analog captures)
dunno how important this is...but just pointing it out... -
P.J.Poopyhead Wrote: problem is, DVDshrink isn't as good. there have been numerous posts on DVDshrink's forums about its ripping problems..... ripping with DVDdecryptor to the hdd first and then letting DVDshrink process it is a much safer way.
Poopyhead Wrote: RCE: you wouldn't notice because you're playing the DVDs in the region it was meant for. try taking a RCE protected region 1 DVD and playing it in a region 2 DVD-ROM. there may be problems.
Poopyhead Wrote: - PUO: you definitely have enountered this....Prohibited User Operations. whenever you try to fast foward the FBI warning, but the DVD player doesn't allow you to...that's PUO. you can remove those restrictions w/ DVDdecryptor...DVDshrink can't
Otherwise:
Just Use Shrink! -
DVDshrink's ripping app isn't as well developed (and with much less options) as DVDdecryptor and smartripper...since DVDshrink's main purpose is transcoding...
furthermore, if you ever encounter commercial DVD5, you don't even need DVDshrink....DVDdecryptor will rip and burn...nothing else is needed..
sample from DVDshrink forums:
http://forum.digital-digest.com/showthread.php?s=&threadid=21275
Originally Posted by dvdshrink
http://forum.digital-digest.com/showthread.php?s=&threadid=21405
Originally Posted by dvdshrink -
Hey poopyhead
you know all that stuff you said about dvd decrypter removing all that stuff?
is dvd decrypter already set up to remove it all or do you have to change some options to do it?
cause when i backed up my Simpson region 1 it would not go past the fbi warning on my pc or region 2 dvd player
it was a while ago when i did this back up so i may not of used decrypter i might of just used dvd shrink. i cant quite remember
but now that i've learnt more i always use
decrypter
dvd shrink
nero -
Originally Posted by watty252
i'm referring to the latest version...and yes, those options are automatically checked...
however, if you are indeed ripping a RCE protected disc, you need to make sure you set in DVDdecryptor the region of the RCE protected disc before you start ripping. -
Cheers poopy head
so i'll have to change decrypter to region 1 for my region 1 disc's
makes sence really
thanks again
watty252 -
I personally use DVD Decrypter only infrequently, since I primarily don't even notice the encryption on discs any more.
I have AnyDVD. Lovely piece of code, that.
- Gurm
BDFree freeware released, decrypt Blu-ray/DVD - free alternative to anydvd
By bdfree in forum Newbie / General discussionsReplies: 23Last Post: 28th Sep 2012, 10:25 -
decode/decrypt mp3,mp4, ipod, mov etc to avi to burn to dvd
By brightpenny in forum Video ConversionReplies: 1Last Post: 16th Sep 2009, 16:24 -
GUIDE: How to Decrypt/store/playback HD-DVD and Blu-Ray Discs
By devilcoelhodog in forum Blu-ray RippingReplies: 7Last Post: 3rd Sep 2008, 05:43 -
DVD Decrypt segment extraction
By kippard in forum DVD RippingReplies: 6Last Post: 24th Feb 2008, 22:30 -
Does Nero decrypt when copying DVD?
By shun in forum DVD RippingReplies: 2Last Post: 2nd Sep 2007, 20:09
