how can i capture songs or video from the internet?
thanks
As for audio streams (which I think is what you are talking about), I believe that there are certain programs out there that can help you record what is beign streamed. And chances are if you watched a video on the internet, then its in your Temporary Internet Files folder. To find this folder on Win98: C:\WINDOWS\Temporary Inter....... On XP you can find it in yoru Local Settings folder.
what programs are there available to capture the streamed audio? and where is the local settings folder?...........i checked control panel and i had a quick search in my C: and i couldnt find it.......
thanks -
For Audio
All Sound Recorder - can record whats "playing"even if its a .WAV file
or
Total Recorder - same deal, records while playing
For Picture and sound
Hypercam
or Snagit
RECORDS both sound and picture from a defined area (defined by you) on the desktop..Real time...
both programs require a 1GHZ or higher for a 30 fps, 720x480 frame.. If you just want VCD size, you can do with less of a system
For Picture only
FRAPS
For EASY RECORDING: I use the next computer over..that is if you don't mind going thru an analog generation and have 2 MACHINES IDLE, you use the VIDEO OUT that shows a clone of your desktop to supply VIDEO to a capture card in a another machine entirely.. and capture to the other machine, including sound output from your sond card -
RipCast Streaming Audio Ripper can be used to record streamed audio in mp3 format.
Ronny
How to capture and burn streaming tv internet video
By robrpb in forum Video Streaming DownloadingReplies: 15Last Post: 4th Jun 2010, 02:02 -
Capture streaming video (off of a internet connection)?
By Po|arbeaR in forum Newbie / General discussionsReplies: 9Last Post: 24th Nov 2008, 18:53 -
Internet to tv
By moonlight in forum ComputerReplies: 5Last Post: 10th Feb 2008, 11:37 -
Kaspersky Internet Security 7.0 installation Conflicting with Internet Exp
By Krelmaneck in forum ComputerReplies: 2Last Post: 5th Oct 2007, 04:36 -
virus internet suites and video capture advice sought.
By DBenz in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2007, 21:19
