Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
  1. Hi all,
    I have a wav. file that i have extracted from anmpeg. I only want the 1st 30 secs or so. How do i seperate this from the main or cut it out?
    thanks!
  2. Member Gritz's Avatar
    Jan 2003
    Ifyou have Windows ME (or below I imagine) do this: Hit Start/Programs/Assessories/Entertainment/Sound Recorder and load up your wav file. Move the slider to where you want to chop to the end and hit Edit/Delete to end of File. Hit the Play and then the spacebar to stop at the desired point. Save the file to a different name to preserve the original.
    "No freeman shall be debarred the use of arms." - THOMAS JEFFERSON .. 1776
  3. Same for WinXP.
