I have made a VCD with a menu that allows one to select which of the three video segments on the disc to watch (1, 2, or 3). After a segment is played, the disc reverts back to the menu. I would like to add a fourth selection that would PLAY ALL of the video segments one after the other and then go back to the menu.
I know that I need to edit the XML file to do this, but I just don't get it. Would it be possible for me to email the XML file to one of you experts and have you modify it for me to get the PLAY ALL function? This would be extremely helpful as I plan to make a series of these types of VCDs all with the same functionality. If I had one XML file that worked, I could use it for a blueprint for the rest of the series.
Thanks in advance!
RowMan
Results 1 to 1 of 1
Overclock Assistance/Advice...
By Moontrash in forum Newbie / General discussionsReplies: 5Last Post: 31st May 2009, 08:10 -
MP4 Playback Assistance
By Madz in forum Software PlayingReplies: 3Last Post: 11th Jul 2008, 12:05 -
Assistance with Capture settings
By kiwiusa in forum RestorationReplies: 0Last Post: 14th Jan 2008, 19:41 -
need assistance getting video clips
By Olshan in forum Newbie / General discussionsReplies: 3Last Post: 21st Sep 2007, 12:50 -
Video Codec Assistance
By 123fish123 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Jun 2007, 07:03
