I tried burning a SVCD with VCDEasy and when I added my video file to the list it said "This MPEG file has bad packets". I tried ignoring this and started to burn the video. When I played it on my DVD player it didn't play the entire video, I'm assuming it stopped where the "bad packet" was. How can I fix my MPEG files to make them burn without errors?
what is the source of your mpg2 files, and what process are you using to create them?
I got the mpg2's off kazaa, i didn't create them. i just tried fixing the mpg2's in tmpgenc with the mpg tools but it about 75% through it stops and says illegal audio stream. is there a better program to fix mpg2's?
I just extracted the audio with tmpgenc to a wav file and then tried to recombine them with tmpgenc but it once again said, "illegal audio stream" do i need to re encode the audio to mpeg layer2? if i do what is the best program to do that with and where can i get it? thanks for all the help
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 18:45 -
Merging MPEG2 stream with its AC3 audio... or converting MKV to MPEG2
By cwt in forum Video ConversionReplies: 2Last Post: 5th May 2010, 14:18 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 16:02 -
MEncoder errors when copying mpeg2 file
By orev in forum Video ConversionReplies: 2Last Post: 22nd Feb 2008, 13:51 -
check a DVD for errors/read errors?
By ebob in forum Authoring (DVD)Replies: 4Last Post: 5th Jun 2007, 10:53
