Hi !
I am trying to encode an avi movie using ffmpegX 0.0.7 (c or d) and I keep getting a small movie (35 Mb) whatever setting I try; I am trying to use mencoder codec (avi or xvid). The image is definitely black.
Here is the log :
Encoding started on Mon Aug 4 22:19:41 CEST 2003
Using GNU internationalization
Original domain: messages
Original dirname: /sw/share/locale
Current domain: mplayer
Current dirname: /usr/local/share/locale
MEncoder dev-CVS-030226-15:00-3.1 (C) 2000-2003 Arpad Gereoffy (see DOCS)
AltiVec found
Reading /Users/legone/.mplayer/codecs.conf: can't open '/Users/legone/.mplayer/codecs.conf': No such file or directory
Reading /usr/local/etc/mplayer/codecs.conf: 55 audio & 141 video codecs
File not found: 'frameno.avi'
Reading config file /Users/legone/.mplayer/mencoder: No such file or directory
success: format: 0 data: 0x0 - 0xDC0AF800
MPEG-PS file format detected.
VIDEO: MPEG2 720x576 (aspect 3) 25.00 fps 9375.0 kbps (1171.9 kbyte/s)
[V] filefmt:2 fourcc:0x10000002 size:720x576 fps:25.00 ftime:=0.0400
Opening audio decoder: [liba52] AC3 decoding with liba52
Using AltiVec optimized IMDCT transform
AC3: 5.1 (3f+2r+lfe) 48000 Hz 384.0 kbit/s
No accelerated resampler found
AUDIO: 48000 Hz, 2 ch, 16 bit (0x20), ratio: 48000->192000 (384.0 kbit)
Selected audio codec: [a52] afm:liba52 (AC3-liba52)
Opening video filter: [expand=-1:-1:-1:-1:1]
Expand: -1 x -1, -1 ; -1 (-1=autodetect) osd: 1
Opening video filter: [scale=720:396]
Opening video filter: [crop=12:12:8:8]
Crop: 12 x 12, 8 ; 8
Opening video decoder: [mpegpes] MPEG 1/2 Video passthrough
VDec: vo config request - 720 x 576 (preferred csp: Mpeg PES)
Could not find matching colorspace - retrying with -vop scale...
Opening video filter: [scale]
The selected video_out device is incompatible with this codec.
VDecoder init failed
Opening video decoder: [libmpeg2] MPEG 1/2 Video decoder v2.0
libmpeg2: No accelerated IDCT transform found
libmpeg2: No accelerated motion compensation found
VDec: vo config request - 720 x 576 (preferred csp: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 1.78:1 - prescaling to correct movie aspect.
SwScaler: reducing / aligning filtersize 3 -> 2
SwScaler: BILINEAR scaler, from Planar YV12 to Planar YV12 using C
videocodec: libavcodec (720x396 fourcc=58564944 [XVID])
High quality encoding selected (non real time)!
Selected video codec: [mpeg12] vfm:libmpeg2 (MPEG 1 or 2 (libmpeg2))
MP3 audio selected
Building audio filter chain for 48000Hz/2ch/16bit -> 48000Hz/2ch/16bit...
Writing AVI header...
New_Face failed. Maybe the font path is wrong. 0mb A-V:0.000 [0:0]
Please supply the text font file (~/.mplayer/subfont.ttf).
subtitle font: load_sub_face failed.
The encoding finishes and announces a 67 kb/s bitrate even if I chose 1314 in th GUI...
Does anyone have an idea?
LeGoneGuest
LeGoneGuest
If that can help somewhat, I can add that I can still encode some other DVD. I noticed that the DVD I cannot encode (I tried to rip it using Osex and YadeX) only have a VIDEO_TS folder and no AUDIO_TS folder. The DVD I managed to encode have both...
Does that help?
LeGoneGuest
I think I have already tried this solution. Anyway, I will test this again.
But do you mean I should put the m2v video file in the input file field (top of the window), encode with my settings the video, encode the audio separately and then finally mux it?
black and white image
By bsn in forum Newbie / General discussionsReplies: 1Last Post: 13th Oct 2011, 13:29 -
adding black to the sides of an image (windowboxing)
By maca in forum Video ConversionReplies: 3Last Post: 30th Jan 2010, 15:21 -
AVI with many black lines (may be black fields)
By jarhead104 in forum Newbie / General discussionsReplies: 5Last Post: 17th Sep 2009, 07:36 -
Can anything be done about black ghosting to R of image?
By brassplyer in forum RestorationReplies: 3Last Post: 4th Aug 2009, 20:47 -
Tiny subtitle
By projecttemp in forum Video ConversionReplies: 5Last Post: 7th Apr 2008, 07:26
