can anyone help
when i copy from dvd to vcd sometimes the odd vcd loses sync with lip movement. its fine on the pc it only happens when i play them on my home player does any one have any ideas at all
i have a cyberhome dvd player
they are supposed to be quite good
This is quite a common problem on many DVD Players. The chipset just can't cope with the VCD feed.
Some solutions:
Sometimes, halting (pausing) the VCD and starting again will help.
Sometimes recording at a slower speed to your disk will help
Instead of burning directly, using VCDImager(GUI) to create an image file to burn
You see 1 problem - and many solutions
Strange lip sync problem
By joe_kargan in forum Video Streaming DownloadingReplies: 1Last Post: 29th Apr 2011, 17:36 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 05:48 -
dvdauthorgui bad lip sync problem
By prioryjim in forum Authoring (VCD/SVCD)Replies: 5Last Post: 2nd Dec 2009, 05:47 -
Divx Lip Syc Problem
By pete7769 in forum Video ConversionReplies: 5Last Post: 16th Mar 2008, 08:42 -
IC For Lip Sync Correction
By SingSing in forum AudioReplies: 3Last Post: 4th Jun 2007, 16:53
