if i have a mpg1 file, can i convert it to a mpg2(svcd) using lsx-mpeg.
I am not sure that this is possible with LSX-mpeg, but it can be done with TMPGEnc. To make an SVCD compliant MPEG-2 file, the source (MPEG-1) movie must have the correct frame-rate (25Hz for PAL or 24 or 30 Hz for NTSC).
<font size=-1>[ This Message was edited by: CornelisJ on 2001-09-30 14:27:11 ]</font> -
Q: Why do you want to do this? The quaility will not be any better, in fact re-encoding it will cause a quaility hit.
At the same bitrate and resolution there's no quaility difference between MPEG1 and MPEG2. The real advantage of MPEG2 over MPEG1 is that MPEG2 supports: interlacing, multiple audio tracks, multiple angles, subtitles, etc. etc.
demuxing mpg2
By volam in forum EditingReplies: 1Last Post: 11th Jul 2008, 15:05 -
VCD MPG1 file to CD Question
By Excelsior123 in forum Authoring (VCD/SVCD)Replies: 21Last Post: 22nd May 2008, 20:14 -
avi to mpg1
By zoranb in forum MacReplies: 3Last Post: 12th Sep 2007, 15:46 -
MPG2 or MPG4???
By JennyBear in forum Newbie / General discussionsReplies: 7Last Post: 1st Aug 2007, 18:33 -
Minimum MPG1 file size?
By Choppa in forum Authoring (VCD/SVCD)Replies: 17Last Post: 18th Jun 2007, 00:04
