I currently am using Pinnacle Studio 8 as my analog capture software and my editing/authoring program. When you get done doing the menus and chapters, there is a "Make Disc" option that creates all of the DVD files for you. This usually takes about 5 hours to complete. I was reading that TMPgenc can do this process as well? Sometimes even better that Studio 8. Is this true? What is TMPgenc's main use? And if it can do this process, can I keep my Menu's and chapters that I created?
Thanks for the info.
"Wanting people to listen, you can't just tap them on the shoulder anymore.
You have to hit them with a sledgehammer,
and then you'll notice you've got their strict attention."
-John Doe in Se7en -
TMPGEnc is an mpeg encoder whose main function is to encode AVIs into MPEGs. It can also cut/ join muilplex and demux, but MPEG encoding is still its main function. Pinnacle Studio, however, is what you want to edit, add effects, menus and such, and finalize your film. Dont confuse yourself as to what they do. They have seperate abilities, and I'd stick to using Studio for what you are doing.
Ok, thanks for the clarification.
-John Doe in Se7en
Basic Issue - want to make video loop using DVD Studio Pro
By Donny Rowles in forum Authoring (DVD)Replies: 2Last Post: 19th Sep 2011, 13:56 -
How To Make Vegas Movie Studio Platinum 10 Use More % Of The CPU?
By JohnnyGalaga in forum EditingReplies: 18Last Post: 30th Jan 2011, 20:19 -
question about how to make picture brighter in TMPGEnc DVD Author3
By jimdagys in forum Authoring (DVD)Replies: 1Last Post: 19th Nov 2007, 00:08 -
TMPGEnc Author Version 2.0 - Unable to make a DVD with a motion Menu
By tug_hill2 in forum Authoring (DVD)Replies: 5Last Post: 28th Sep 2007, 00:37 -
How to Make Authored DVD INTO .ISO WITH TMPGENC DVD AUTHOR
By Chupes in forum User guidesReplies: 4Last Post: 19th Aug 2007, 17:38
