And how is it done, I can make movies ok and I can make a picture cd with audio but can I have the disc open with a menu that gives the option of playing the movie or playing the mpeg stills with audio and being able to move through the stills at will? Thanks for anyone who can answer this....
Yes you can mix with VCDEasy video streams and still pictures. VCDEasy recognizes automatically the mpeg-files and makes the correct settings for you. You have only take care to set the correct setting in the interactivity menu to reach your wished results.
Regarding moving through stills it depends which method you are you using. I discussed two different methods where one allows the moving between stills whereas the second method does not allow it. If you have enough space on the CD then you can store the mpeg-stills separately to allow the moving throw the pictures.
Jürgen
Inserting photos in a music video with movie maker
By Olustee bus in forum ComputerReplies: 0Last Post: 5th Sep 2011, 12:30 -
Here's something the music and movie industry doesn't want you to know
By nic2k4 in forum Latest Video NewsReplies: 2Last Post: 22nd Jul 2011, 20:28 -
first time problem : can't find boot dsk on startup
By beavereater in forum ComputerReplies: 22Last Post: 24th Jun 2011, 17:09 -
movie, music, book, etc suggestions...
By deadrats in forum Off topicReplies: 8Last Post: 6th Sep 2009, 22:27 -
Are RW DVDs secretly targetted by movie and music producers?
By maxhalt in forum Authoring (DVD)Replies: 1Last Post: 27th Sep 2007, 09:09
