I wanted to which is the most compatibility or playable with set top DVD player UDF 1.02 or UDF 1.05 because I was planning on distributing a few of my DVD that I have made(beachparty weekend dvd) and can I change UDF using RecordNowDX.
Thanks in advance to all that reply.
Results 1 to 16 of 16
XXL
Actually, it's UDF 1.02 or 1.50. For the most compatibility, use 1.02.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Hmmmm.... i wonder...
I know that UDF 1.02 is most compatible ... but i have the problem that when i use Nero to burn in UDF 1.02 (UDF/ISO), the resulting movie gets stretched.... resulting the subtitles not to display properly on the TV.
Any idea what i'm doing wrong?? -
Actually, tyoneXXl was right...it's UDF 1.05, NOT 1.50.Originally Posted by SLK001
@tyoneXXl,
well, your DVD player supports DVD-R/+R???
https://www.videohelp.com/dvdplayers
also, if UDF 1.02 isn't working for you, then try 1.05.
there are also other burning proggies.....
- nero express
- Instant CD/DVD: https://www.videohelp.com/instantdvd.htm
- PrimoDVD
- RecordNow -
Well for me, 1.02 works in my DVD player and 1.05 does not. There's no gain at all in using 1.05 either.
ImgTool is also an excellent way to make DVD images. You create an .iso image with ImgTool, then can use DVD Decrypter or any other burning program to burn it (and ImgTool + DVD Decrypter is free). I've been trying out ImgTool Burn lately which is the same thing except it uses the Nero burning engine to go directly to disc without the .iso file creation step. Nero works fine this way because ImgTool bypasses all the weaknesses in Nero's DVD creation code. I don't think it can do UDF 1.05 though, just 1.02.
both of you are rightOriginally Posted by poopyhead
it depends on the program
nero 1.02 and 1.05
gear and instant cd/dvd 1.02 and 1.50
1.05 and 1.50
same difference -
https://www.videohelp.com/forum/viewtopic.php?p=594948&highlight=#594948Originally Posted by LanEvo7
Then I guess the Optical Storage Technology Association must be wrong?Originally Posted by poopyhead
http://www.osta.org/specs/index.htm
https://www.videohelp.com/forum/viewtopic.php?t=127624
ppl mention UDF 1.05....NOT 1.50
Originally Posted by snowmoon -
poopyhead,
That's another Nero bug/typo!
There is NO SUCH THING AS UDF 1.05--they meant 1.50
The OSTA CREATED the UDF specs, and they state that there are these versions:- 1.02
1.50
2.00
2.01
2.50
Of course, maybe Nero IS burning with V1.05 and that's why there are compatibility problems!
Scott - 1.02
Record files over 4 Gb in UDF?
By Artas1984 in forum MediaReplies: 2Last Post: 8th Dec 2011, 14:53 -
UDF Video
By Axissally in forum Video ConversionReplies: 11Last Post: 22nd Feb 2011, 14:47 -
UDF 2.5 driver for XP 64bit
By INFRATOM in forum Blu-ray RippingReplies: 2Last Post: 20th Mar 2010, 12:27 -
Burning with UDF
By gooberguy in forum Authoring (Blu-ray)Replies: 9Last Post: 18th Jul 2009, 18:01 -
converting udf to ntsc
By crazyn8 in forum Newbie / General discussionsReplies: 2Last Post: 19th Aug 2007, 17:07
