I have an import Japanese DVD that has horrible subtitles. What can you expect when you have Chinese guys translating Japanese into English :P . I used SubRip 1.17 to extract the subtitles and saved as a .txt file to edit the grammer, spelling, etc. Once I am done that you can save the file in many formats including .sub files.
My question is once I am done editing, how do I get the edited file back into the IFO using IfoEdit? Has anyone done this before?
"Can You Dig It!"
No but have the same question only my ifo is for a 2 eps dvd i made with dvdlab.
Greatings,
Yf -
Arrgh! I wish the Forum Search was working
I have found a guide using IfoEdit to extract and re-insert the subtitles here:
http://www.dvd2dvdr.com/part_iii_Ifo.htm
But you have to re-encode the VOB files with TMPEGEnc to a MV2 file to be converted back to a VOB file later (Why?). All I want to do is substitute the current subtitle stream with a new one. Is there no way to rename the file the same as the current one and replace it?
Help!"Can You Dig It!" -
You need srt2sup to convert your subtitles in srt format to the sup format IfoEdit uses.
http://www.dawnload.net/video_software/subtitle_tools/srt2sup.cfm
You should also take a look to Subtitle Workshop, it has many features, and can convert between lots of formats ( not .sup
Thanks Lautaurus. This looks exactly like what I am looking for. Now I just have to figure out how to get it into IfoEdit.
"Can You Dig It!" -
OK, I have got this planned out pretty well (I think)
1) Use SubRip 1.17 to edit subtitles.
2) Use srt2sup to convert .srt file to DVD compliant subpicture stream.
3) Re-author the DVD using IfoEdit so I can insert new sub stream.
Looks good on paper. After I sit down and re-edit the whole 45 minutes of dialouge, I will let you know how it turns out.
Thanks for the help."Can You Dig It!"
Putting subtitles on MP4 files?
By Cooperdk in forum SubtitleReplies: 0Last Post: 6th Dec 2010, 06:09 -
Ripping a DVD, editing it, then putting it back onto a new DVD. HELP!
By CaptainZissou in forum MacReplies: 11Last Post: 6th Feb 2010, 23:18 -
converting IFO to SRT subtitles
By weiq in forum SubtitleReplies: 1Last Post: 4th Mar 2009, 04:39 -
Is it possible to embed IFO into VOB so PS3 can see the subtitles?
By siratfus in forum SubtitleReplies: 0Last Post: 31st Jul 2008, 13:05 -
question about putting subtitles into avi
By pike8 in forum SubtitleReplies: 2Last Post: 15th Jun 2007, 11:42
