hi there,
i want to insert an i-frame at a specific point in the mpeg-file to be able to set a chapter point later when authoring. if you enter a frame#, cce (i'm using 2.66) will automatically add a second i-frame at frame# 0 with the number format 0000.
my frame# is 724, so i tried 724 and 0724. i chose 12 frames/GOP with a sequence header at each single GOP. Thus, my GOP structure is
/IBBPBBPBBPBB/.
i also tried the 'restrict auto i-frame insertion' option which is known to slightly decrease image quality. none of the above settings worked. opened in virtualdub, there's a regular i-frame at frame# 722 (regular meaning it's at the beginning of a new GOP).
Trying the same GOP-structure in tmpegenc it worked, but in virtualdub there's a regular i-frame at frame# 720 and the desired one at 724.
use tmpegenc you'll suggest, but i'd rather use cce+avisynth, since it's faster and gives better quality results. i figured it could have something to do with the quantization matrices, but that's just a guess.
Anyone got ideas/same problems/solutions to this (other than using tmpegenc) ?
greets,
honfrek -
me again,
plz forget about the quatization matrices! it's got nothing to do with that.
it seems to me that i have to move the preview slider up to the frame i want to insert the i-frame at and then click on set. just typing in the frame# and clicking set adds frame 0000 and the typed-in frame# to it, cause the slider is at that position. normally, that shouldn't be a problem, since there's an i-frame at the beginning anyway.greets,
honfrek
AVIDEMUX Inserting I-Frames?
By MJS in forum EditingReplies: 6Last Post: 28th Jan 2011, 07:00 -
Inserting blank frames with logos before movie start
By multiplex in forum Newbie / General discussionsReplies: 9Last Post: 1st Oct 2008, 20:30 -
AppleScript Error _iframeflag is not defined (-2753)
By linea in forum ffmpegX general discussionReplies: 3Last Post: 30th Jun 2008, 12:51 -
By linea in forum ffmpegX general discussionReplies: 10Last Post: 30th Jun 2008, 12:46 -
User-defined chapter points
By saber540ltd in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 26th Mar 2008, 18:38
