i went to burn the movie i have with nero but it says it needs to be encoded? what is up with that!
i open tmpgenc but it wont let me open the file
What do i do
What type of mpeg is it and what are you trying to burn it as.
if you have VCD MPEG-1 file, make sure you use nero's VCD template.
if you have SVCD MPEG-2 file, make sure you use nero's SVCD template....
so, if you matched the type of .mpg file with the correct template in nero and nero still wanted you to re-encode, then try unchecking the box next to "make standard, compliant disc"
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 19:49 -
Cannot burn an mpg on a DVD
By costaseco in forum Authoring (DVD)Replies: 2Last Post: 12th Nov 2009, 03:15 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 16:11 -
Burn MPG file onto DVD
By geek2330 in forum Newbie / General discussionsReplies: 15Last Post: 2nd Oct 2007, 08:51 -
Burn mpg on DVD
By knowmyname_20 in forum Newbie / General discussionsReplies: 3Last Post: 27th Aug 2007, 19:31
