Is there anyway to convert an ifo file that i ripped with dvd decrypter and compressed with dvd shrink to an iso
if so what programs do i use
hi tim
not sure what your asking is possible, see an ifo is only a file which tells the dvd player which vob to play, what chapter to play or what to do when a movie is starting or finishing, there is other stuff you can tell an ifo in what to do, but that is generally what an ifo file does. BUP is usually a backup of the IFO.
I think what you maybe asking is how to convert a set of vobs to an iso image, correct me if im wrong, if that is the case then you can use DVDdecrypter to make an iso image, just go to MODE then ISO then READ, select the source and then set the destination.
kas187 -
what i want to do is take the movie that i have ripped onto my computer and burn it to DVD-R as a iso file because i can not get it to work when i burn the ifo file
Hi Tim
if you want to turn your files in to an iso.
Go to the Tool section on this site & look for imgtool
Once you found it down load the classic imgtool.
this is a real simple tool to turn files in to iso's
Hope this helps you[/url]
Using DVD Decrypter should I use .ISO or .IFO file !
By augustya in forum DVD RippingReplies: 21Last Post: 29th Mar 2012, 12:44 -
.ifo/.sup subtitle pair - what's in the .ifo?
By MilesAhead in forum SubtitleReplies: 2Last Post: 5th Mar 2010, 00:02 -
I convert mpeg2 to iso, then what? Can I covert iso to VOBs?
By BeerSnob in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2008, 19:01 -
DVD Shrink to VOB,IFO, BUP and then IMGtool to ISO, bigger than 7GB
By opieandy in forum DVD RippingReplies: 3Last Post: 28th Sep 2007, 16:04 -
4 separate IFO files > one IFO to govern the full .VOB video
By Salva Veritate in forum EditingReplies: 4Last Post: 20th Aug 2007, 14:38
