I was using winme, upgraded with the full version to xp so I could take advantage of the longer capturing time. Had been using ScenalyzerLive to capture analog because Pinnacle had the audio sync problem & had great success with scenalyzer. Was using the nov. 2002 version of scenalyzerlive but I can't get it to work now. Upgraded to the latest version to give that a try, but still no success.
It's seeing the pinnacle capture card but when I press the button that says to push it when the device is connected, it looks like it's going to connect, but nothing, it just pops back out & I get no preview of the video. I was able to capture with the pinnacle software, same old dropped frame problem, but scenalyzer will play it back. Also, when I used to turn the vcr on, the static sound was quite loud on scenalyzer, don't remember what it was in pinnacle, but now there's no static sound at all with scenalyzer, & the pinnacle volume is very low. I have done all the window upgrades that were available.
Any suggestions would be greatly appreciated.
Results 1 to 1 of 1
Problems with Pinnacle Studio 9 using DC10+ Capture Card
By alexh110 in forum Capturing and VCRReplies: 0Last Post: 29th Jul 2011, 04:03 -
MP20 Capture Card and Pinnacle Studio 14
By egee17 in forum Capturing and VCRReplies: 0Last Post: 26th Feb 2011, 20:30 -
Pinnacle AV DV capture card
By pawan.bishnoi@gmail.com in forum Capturing and VCRReplies: 0Last Post: 30th Jan 2011, 13:45 -
Capture with DC 10 Pinnacle Card with OS Win 2k and Pinnacle studio11
By fjmr in forum Capturing and VCRReplies: 2Last Post: 7th Apr 2008, 18:02 -
Unknown Pinnacle Capture Card
By Signal in forum Capturing and VCRReplies: 6Last Post: 24th Jul 2007, 20:03
