Hi,
Great program, ffmpeg! Thanks for all of your hard work!
Normally I have no problems encoding divx files from a source VIDEO_TS folder that I've ripped using DVD Backup. But for a couple of the VIDEO_TS folders I've got, when I start the encoding, it only goes for a couple of seconds and then finishes.
The resulting divx file is only a few kilobytes in size and isn't the full movie, but instead just one VOB's worth of data.
Is there some way to force ffmpeg to read data from all of the VOB files instead of stopping after just one?
Thanks!
Results 1 to 1 of 1
The UnDougGuest
VideoReDo doesn't Save/Output entire file after editting out commericals
By peter11815 in forum EditingReplies: 1Last Post: 19th Sep 2009, 15:41 -
Ffmpeg command to encode ENTIRE DIRECTORY?
By sumpm1 in forum LinuxReplies: 2Last Post: 27th Sep 2008, 09:40 -
Advice on encoding TV Shows (VIDEO_TS to DivX)
By captvanhalen in forum ffmpegX general discussionReplies: 5Last Post: 10th Dec 2007, 11:48 -
Video_TS to Divx. super poor quality after encoding
By mistervolcom88 in forum MacReplies: 5Last Post: 13th Sep 2007, 14:49 -
any way to make changes and not to encode entire slide show
By tryintoo in forum Authoring (DVD)Replies: 0Last Post: 9th May 2007, 18:02
