I have just done an 81min DVD rip to Pal VCD using DVDx.
I then cut the mpeg with TMPGenc to 79 mins.
When I add it to Nero to make a disc it say the audio is for SVCD so I have to turn the compliance off. The problem then is the bar goes right off the scale with the Mpeg to big for an 80 min cd!
In the set-up for DVDx the audio says AC3 6 channel. Is this not Dolby Digital which you can't use for VCD only SVCD? When I have tried to use the 2 channels listed on other DVD's all I get is the director talking or stuff like that.
I re-encode with TMPGenc and then the mpeg added fine but I don't want to have to do this all the time.
What do I do in the settings to get DVDx to work Properly?
I have done a scan of the files and can't see why the DVDx rip won't work?
Before Convertion
MPEG1, PlayingTime=4741.120s, Bitrate=1393600bps, PtsOffset=0345s, 403437 packets
Video Stream: Motion Video, 288x352, 25fps (PAL), 1150kbps
Audio Stream: Audio Standard MPEG layer2 Stereo, 44100Hz, 229376bps
When I add the above file to Nero it says "Steam encoding which is invalid for a (super) video-CD"?
I don't understand this as Im making a VCD not SVCD?
After Convertion with TMPGenc
MPEG1, PlayingTime=4741.146s, Bitrate=1411200bps, PtsOffset=0346s, 355604 packets
No problems with Nero and Plays fine?
I thought the audio was a bit above the standard at 229376bps but its still the same after convertion?
Any ideas?
I de-multiplexed then re-multiplexed the file and now it works fine?
What's wrong with the original?
Probelm with DVDx 4.0
By vevdare in forum DVD RippingReplies: 0Last Post: 13th Dec 2011, 23:57 -
New DVDx 2.20 release is out!
By Jim@labDV.com in forum Latest Video NewsReplies: 3Last Post: 16th Jun 2009, 02:53 -
DVDx dropping audio at end of vob
By shira in forum DVD RippingReplies: 0Last Post: 21st Jan 2008, 23:42 -
New DVDx InfoTool is out
By Jim@labDV.com in forum Latest Video NewsReplies: 0Last Post: 22nd Dec 2007, 09:32 -
Error in DVDx?
By php111 in forum Newbie / General discussionsReplies: 1Last Post: 6th Oct 2007, 15:17
