I capture TV programs using Snapstream, edit them with Womble and end up with MPEG2 DVD compatible output files. I also create files captured from a DC10+ and converted using tmpgenc to DVD compatible files. I have just found one strange behavior. Authored two mpeg files from Snapstream and Womble using DVD Movie Factory - files show up in DVD MF as 720x575 (PAL) aspect ratio and author and burn fine. But when played on my DVD player (as well as PowerDVD) they are 16:9 - show up as widescreen images. A check of the video_ts.ifo file using ifoedit shows that the AR is indeed 16:9 which is really strange. Files that have come from the DC10+ via tmpgenc and then authored using DVD MF have the right AR. Anybody ever experience this? It's really strange and I don't know what settings to change to fix it apart from having DVD MF create the video_ts directory and not burn and I fix the video_ts.ifo file using ifoedit before burning which is a bit tedious
Larry
Never mind - seems to be a one off problem. I re-authored the DVD and saved the video_ts files. Checked both video_ts.ifo and vts_01_0.ifo and both showed the video as being 16:9 for some reason. Fixed it in ifoedit and once the files were burnt using Nero, the video plays back in 4:3 format. Captured and authored another video and using the same process, the output format is 4:3 with no fiddling - go figure!
Larry
DVD to an edited MPEG-2 file with MPEG audio: Trouble/please help
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 21Last Post: 9th Aug 2011, 09:52 -
How do I make an MPEG-2 dvd compliant file into a authored dvd?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 13Last Post: 12th Mar 2009, 16:10 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36 -
Burn authored VIDEO_TS as UDF or CDFS (or RAW) file system format?
By PCat in forum Authoring (DVD)Replies: 4Last Post: 26th Jan 2009, 17:33 -
burning and authored mpeg to dvd?
By just in forum Newbie / General discussionsReplies: 21Last Post: 12th Dec 2008, 10:06
