i took a snapshot of a capture i did tonight and you can see there are serious image shifting going on...i know for a fact that this is related to my cable signal...so what can i do to resolve this shifting problem...is there a filter i can use or am i forced to deal with this?
Results 1 to 13 of 13
I had something similar to this which I solved with a signal booster.
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
Yes, you really need to sort your signal out going to the capture card. Filtering is not going to help you here. Does it look like that when you watch on your TV, if not how have you split the signal. I would reccomend splitting the signal via a booster like will suggested
yes it looks like that on the tv...the weird thing is, when i capture using my tv card in my computer the image shift is little to nothing
on the cable wire coming into my house it is split between my tv and my computer
i will look for signal booster then...are they expensive? -
I believe the technical term for that is "ghosting." You may be able to do a google search and find more help too....
Originally Posted by almostaborted
And you are paying for this via a cable service, or is this from an ariel/antenna
i am paying for cable
but this is off fox, which is a free channel and also upn are the only channels that give me problems....the real cable channels like mtv, cnn, bravo and what not come in perfectly
in fact i find that if i unplug the cable wire going into the tv i get better fox reception but there are still artifacts like diagonal lines across the screen....
by the way i live in san francisco where there are a lot of apartment buildings that could be the reason for poor reception -
i got a signal booster for 25 bucks at fry's and it works nicely...thanks a lot!!
Excellent
signal booster???
the problem here is clearly incorrect line termination,the wires are not terminated correctly and there are reflected waves ,with other words your RF cables are a mess.
amplifier will make things worse.
fix your cables,splitters etc.. -
capturing PAL signal as 1080i, 720p or just PAL ?
By adom in forum Capturing and VCRReplies: 3Last Post: 30th Aug 2011, 05:10 -
Capturing 720p HD HDMI signal via Blackmagic Intensity wierd interlacing?
By TermiATT in forum Capturing and VCRReplies: 22Last Post: 1st Jun 2010, 12:31 -
Card for capturing HD Component Signal
By peez in forum Capturing and VCRReplies: 4Last Post: 10th Nov 2009, 09:42 -
Sporadic signal losses while capturing analog gaming footage w/ camcorder
By Nintendo Fan in forum Capturing and VCRReplies: 0Last Post: 17th Oct 2008, 18:45 -
"No signal"-capturing from VHS-tape
By Mållgan in forum Capturing and VCRReplies: 7Last Post: 19th Sep 2008, 03:21
