If all i do is cut out some portions from my clip and the entire clip is 1 hr long i find it a lot of time wasted if i have to render the whole (DV) movie. Is there some way by which one can getaway without rendering the whole film just cut and save![]()
Is some other (free program better for such purpose?
you can do it in virtualdub , vegas and other programs .. like the newest version of premiere..
Sure there's a way. After you render your movie. Use the razor tool to cut out the portion of the film you don't want to use. It keeps the rest intact. Or use the razor tool to segregate the portion of the movie you want to make an adjustment to.
Sure there's a way. After you render your movie. Use the razor tool...
Premier will need to re-render the movie after you edit or make any changes. Unfortunately, rendering for a finished product doesn't work like rendering for a preview.
frameserving dvd to premiere to avoid demuxing, is it possible?
By codemaster in forum EditingReplies: 3Last Post: 7th Jan 2011, 15:11 -
Final Cut Pro - Rendering out to 4:3
By Jeff_NJ in forum MacReplies: 3Last Post: 27th Jun 2009, 08:01 -
How can I edit (cut) segments from a H264 AVCHD video without re-rendering?
By kmmoore in forum EditingReplies: 5Last Post: 14th Dec 2008, 12:51 -
DV -> Premiere Pro -> DV is recompressing. How specifically to avoid
By Colmino in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 5th Jun 2008, 02:24 -
final cut expess HD rendering... why so slow?
By ednarophati in forum EditingReplies: 0Last Post: 18th May 2007, 15:22
