well basically, i tried changing a film to VCD and there was no sound, so i used virtualDub as advised, to seperate the audio from the video, but for every film i try and do this on i get the same error, at the same point in the program, i click on "full proccessing method" after opening a film, then i click on compression, as it says on this website, and when i click on compression the program comes up with an error and exits, its driving me mad, can anyone help me please?
Results 1 to 10 of 10
You may as well try a program called Gold Wave. Load your video into it, and save the file as a wave file.
Hello. -
i want to seperate the aduio from the image, not completely change it, or is that what it will do?
it does it with 2 films that i have, not sure what audio they have, but it says on this site that you need to seperate the audio from the video, then in tmpeg, where you chose the audio and video, if the audio is not seperated it automatically loads it to tmpeg at this step, but if it is seperated you locate it yourself, anyway, this website specifically told me i have to seperate the audio from the video, no matter what the audio or video type is.
it works now i think, just in the middle of doing it now, no error yet though *crosses fingers* thanks a lot mate
use "Direct stream processing" in VD to demux audio and video
no need to re-encode something when ya dont want/need to
AMD 64 X2 6000+ @3,000 Mhz (stock) | MSI K9N Ultra | Corsair Value/Kingston 6,144MB DDR 667 | 8800GT stock | 3710GB of storage | Powered by Mandriva 2009.1
Jabber: DaveQB@jabber.org.au
2.6.29.3-desktop-1mnb
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 14:26 -
Help with VirtualDub 1.9.7?
By hezbag in forum Video ConversionReplies: 4Last Post: 20th Oct 2009, 06:21 -
Virtualdub help
By Rogert in forum Newbie / General discussionsReplies: 10Last Post: 2nd Sep 2009, 16:00 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 18:08 -
Help with VIRTUALDUB Please !!!!
By spliffy in forum RestorationReplies: 10Last Post: 30th Jun 2007, 09:28
