How do you convert a avi file so it can be made to a vcd or svcd? I'd appreciate the help with this! I tried using tmpge to convert it and it does not work. Thanks in advance!
Results 1 to 9 of 9
You can load your avi file into an encoder (such as TMPG) directly and encode, or you can frameserve the file to an encoder. What happened when you tried to use TMPG?
I got a error msg saying the file was not supported. I'm clueless as to what to use to convert the avi file.
Go to the environmental settings and open it up. Click on the VFAPI plugin tab and make sure the direct show multimedia file reader has a priority of at least one. See if that helps.
I checked the enviromental setting and for direct show multimedia there is a -1 showing. I tried opening up the avi file again in TMPGE and I still get the error msg saying not open and not supported. Thanks for helping me out.
Increase Direct Show until it is 1 or higher, and it is the first one in the list.
Hello. -
Um lol how do I increase it in TMPGE? I'm still a newbie at this stuff. Thanks for replying to my post.
Change the priority from a -1 to a 1. Position your cursor over the words direct show.... Then right click and a drop down box appears. Choose higher priority. It will change to 0. Do this again and it will change to 1.
Thanks LadyDaddy it worked. I'll let you know if the encoding works out.
Mahalo (means THANKS in Hawaiian)!
How to convert an .avi or .mkv or .mp4 file to mpgav for burning to a VCD
By jasoothai in forum Authoring (VCD/SVCD)Replies: 8Last Post: 29th Oct 2011, 19:35 -
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 02:07 -
How to convert the 1gb VOB file to 80Mb AVI file ?
By zohaibshaikh in forum Newbie / General discussionsReplies: 3Last Post: 17th Oct 2010, 06:41 -
How to make AVI file to 1.4GB ?
By zovx in forum Video ConversionReplies: 2Last Post: 5th Feb 2010, 10:24 -
I want to demux an .mp4 file and convert to a microsoft dv .avi file
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 4Last Post: 13th Sep 2009, 21:42
