Alright, using TMPGEnc Plus 2.5, I split a movie in two, encoded them one after the other, and made vcds out of them. I checked only about 10 min of each converted file before putting it on cd, and everything was perfect! When watching on my dvd player, each vcd goes black after about 30 min, yet maintains sound. I went back to my computer to find that the two files on my computer went black in the same place. So that rules out any burning issues. The pre-encoded movie doesn't have any problems with video or sound. Has anyone encountered this problem? Or does anyone have any suggestions? Thanks.
~Brent
-- Common TMPGEnc ProblemsIf you get an error message when opening like file unsupported or can not open or is not supported
or you get an empty(black) video preview window
or the video look wierd in the video preview window like green or purple or pink
Try first to change the directshow codec reader priority settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 1 or 2 or to the top of plugin-list and try open the video.Hello. -
did you check for and remove bad frames before you encoded with tmpgenc? if not, there's a guide on how to do this to your left.
Color Issue Post BD Rebuilder encoding
By Brett4u6 in forum Blu-ray RippingReplies: 0Last Post: 6th Jul 2011, 15:58 -
TMPGENC encoding problem
By whschlebaum in forum Video ConversionReplies: 0Last Post: 26th Apr 2011, 23:22 -
CUDA - Accelerated encoding for post production
By Wile_E in forum Newbie / General discussionsReplies: 2Last Post: 6th Jan 2011, 07:58 -
Post examples of scenes with "fade" in them for encoding w/ x264
By vhelp in forum Video ConversionReplies: 1Last Post: 8th Sep 2009, 03:27 -
TMPGEnc Plus Encoding
By crys94 in forum Video ConversionReplies: 9Last Post: 29th May 2008, 23:23
