what can i do to solved this ???
nero versio 5.5.10.35 enterprise edition
It isn't a Nero error, it is Nero reporting an error from the drive.
Either the Media is bad, or like the last time I had that from a plextor CD-RW drive, the drive is bad.
Good Luck -
Or, like the many times
I've seen it, the rewritable disk is dirty. Clean it with cold water and hand soap, rinse it well and dry it with a hand towel and then with a soft cloth to remove fibres and any water left. It would then work fine.
The more I learn, the more I come to realize how little it is I know. -
it isnt a rw disk but a princo 4x disk and a nanya 2 x dsik boyh worked before.........
the rw disk just burned fine -
gotta be an a05
its the media list so kindly written into the a05
stopping the calibration -
Yes it is a pioneer 105 ....Originally Posted by Luddite
but the rest you saying now i dont understand
VOB Error While Using Power DVD 10
By skorpinok in forum DVD RippingReplies: 3Last Post: 24th Aug 2010, 15:27 -
Imgburn - Power Calibration Error message
By concisa in forum Authoring (DVD)Replies: 6Last Post: 12th Nov 2009, 16:39 -
Power Calibration Area Error
By zork152 in forum DVD & Blu-ray WritersReplies: 4Last Post: 20th Jul 2009, 18:27 -
JVC HDD Camcorder/Cyberlink power director file import error
By lonewolf_mb in forum Newbie / General discussionsReplies: 7Last Post: 29th Dec 2008, 22:53 -
Nero's "Power Calibration Error" fix.
By AlecWest in forum Newbie / General discussionsReplies: 0Last Post: 8th May 2007, 20:26
