Hi all, I am using DVD-Lab and I am trying to put two movies on the same DVD. One has AC3 sound and one has MPA sound. When I compile DVD-Lab gives me a warning and when I am playing the DVD in my player the AC3 soundtrack is working but the MPA isn't. I transformed my AC3 to MPA and everything is working fine, but my problem is that I lost 5:1 sound
I am pretty sure that the main problem is that DVD-Lab put my two movies in the same VOB set and it doesn't like the audio mix. Is there a way where I can create two set of VOB, so I could have AC3 in one VOB and MPA is the other? something like Movie 1 in VTS_01_1.VOB set and Movie 2 in VTS_02_1.VOB set?
Thanks in advance.
why not convert the MPA to AC3 with BeSweet? that way, you could have AC3 on the whole thing...
just a thought... -
make a seperate title for each movie -- each can have its own type of audio track ..
also how you can mix 16:9 and 4:3 correctly on the same disk .. -
Master: I tried converting MPA to AC3 with BeSweet, no luck that way, I don't know why. Could it be because one of the audio track is stereo and the other is 5:1?
BJ_M: What you mean exactly? How can I do that in DVD-Lab? Or do I have to use another authoring program?
Thank you -
doesn't DVD-Lab do multiple titles? if not - well authoring programs like Maestro do , but i would think others do as well ..
yes - the audio has to be the same per title (either 2ch or whatever) ..
but as a last resort -- convert your 2ch mps to 5:1 ac3 ... only the front L + R channels need to contain audio data ... -
I had a similar problem as well, when I converted my mpa file to AC3 I still had a problem on one player because the mpa->ac3 file was encoded at 256 and my other ac3 was 384. I converted the mpa to ac3/384 using besweet and my disk works great.
Don't know if the ac3 files have to be the same bit rate in the same title set but works for me. -
in theory -- no they dont have to be the same bit rate ... but most authoring apps will not mux a stream with different bit rate audio .. but you can join them by yourself and then import the whole stream into a authoring app and that will work ..
MPA to AC3
By Benjy in forum AudioReplies: 6Last Post: 14th Jun 2011, 06:52 -
How to convert WAV/MPA/MP3 to AC3 6 channels?
By katalogas in forum AudioReplies: 8Last Post: 16th Feb 2010, 14:12 -
Convert ac3 to mpa
By pcb in forum AudioReplies: 3Last Post: 5th Jan 2010, 12:39 -
How do I convert an mpg file using AC3 to use MPA instead?
By bmoret in forum Newbie / General discussionsReplies: 3Last Post: 29th Apr 2008, 09:19 -
Mpa to ac3 5.1
By garherd in forum AudioReplies: 6Last Post: 3rd Sep 2007, 18:43
